Old 04-21-2017, 09:59 PM   #1
Low Point Drains Leaking!
First camping trip with new MicroLite 25BDS. Low point drains won't stop leaking like a sieve. Black, ribbed caps are tight. Nothing in the worthless manual. I'm ready to head home. Anyone have same problem on initial fill with pump turned on?
iMaki is offline   Reply With Quote
Old 04-21-2017, 10:15 PM   #2
Left Coast
Propably the gasket missing.....Pull the cap off and insert a regular garden hose washer
Old 04-21-2017, 10:29 PM   #3
B and B's Avatar
Here is what they look like.
http://www.forestriverforums.com/for...in-119345.html
Do you have saran wrap? Ball up a piece and place it inside the cap and tighten.
Old 04-21-2017, 10:34 PM   #4
Left Coast
If there's a leak, should also show up on city water
Old 04-22-2017, 01:37 PM   #5
RadRik's Avatar
Leak
I used pipe thread tape to fix mine until I could get the washers needed for the bottom of the caps.
Radi-cool Rik
RadRik is offline   Reply With Quote
Old 04-22-2017, 02:58 PM   #6
Yes the washers must have gotten lost or something. Mine came with the washers inside the caps.
rjgrady is offline   Reply With Quote
Old 04-22-2017, 03:25 PM   #7
I used an O ring type washer and never leaked a drop again.Got the size to fit snug in cap. Cheap good fix.
model71 is offline   Reply With Quote
Old 04-22-2017, 04:33 PM   #8
Turns out the caps were put on too tight, and the gaskets were damaged. All is well now. Thanks for the help everyone!
Old 04-23-2017, 01:54 PM   #9
Road grit got in my caps and eventually made them leak. Happy day when I cut them off and crimped on 2 ball valves.
2011 Sabre Silhouette 260BHS
2017 F-350 XLT CC DRW 6.7L
tinkerreknit is offline   Reply With Quote
Old 04-23-2017, 02:00 PM   #10
I just screwed on my ball valves to the existing threaded male ends.
Was yours a different setup?
325BH is offline   Reply With Quote
Old 04-23-2017, 02:01 PM   #11
Left Coast
Some stick down pretty far....
drain, leak
