07-19-2015, 06:24 PM
main door leading into trailer
Hello
On my microliter 25DS i noticed that when the outer door is just about closed, it feels a little stuck and like it is rubbing on the top of the frame. Then I just push it all the way in.
There indeed are two areas that looked rubbed on the top frame of the door.
Is the door out of alignment; also could it mean that the TT is not level?
We are a semi newbie on TT care and was wondering if you can give me some insight.
07-19-2015, 07:52 PM
Happens sometimes when new owners use the stabilizers for leveling.
Ultralite frames, like yours, can easily be twaked doing this.
07-19-2015, 08:14 PM
We generally put wood boards under it for leveling side to side. How else should we level it and how to fix it?
07-19-2015, 08:26 PM
We have a new Flagstaff 27rlws. If we snug down the front electric stabilizer at all the door sticks like that at the top rear side of the door. I cannot see anyway of adjusting it. And no we do not use the stabilizers to level.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
07-19-2015, 08:44 PM
What is meant by " Snugging " the front. Yes we do try to level front to back otherwize we are walking downhill inside. Maybe we shouldn't be so exacting perhaps?
07-19-2015, 08:45 PM
Left Coast
I'd adjust it a little with a block of wood and a hammer if that's what it took...just be gentle....maybe the jamb needs the adjustment.
07-19-2015, 08:52 PM
We level side to side with boards. Then we level front to back with the tongue jack. Then I put down the 4 corner stabilizer jacks down enough so they are tight to the ground but not lifting or carrying any of the weight of the trailer. I was referring to the 4 corner Jack when I mentioed snugging them down. The front one on the door side is real sensitive. I tighten it down or snug it down a little too much the door does not shut properly.
Orval and Yvonne
no, i said the stabilizers, not boards under the wheels, which is the correct way to level side to side.
many new owners try to use the stabilizers to lift the trailer for leveling, which shouldn't be done.
07-19-2015, 09:04 PM
X2 or adjust it like they use to do car doors by putting a 2x on the sill and bumping the door against it.
07-23-2015, 12:24 PM
thanks all!
We are going out camping this weekend and will see what happens.
We do level by putting boards under the wheel and front to back with the hydraulic tongue jack. We will see what happens today.
07-23-2015, 12:49 PM
thanks all!
Are you sure you have a (Hydraulic Tongue Jack)? Youroo!!
07-23-2015, 01:07 PM
Probably wrong terminology youroo. My hubby has it all figured out
Thanks again!
08-04-2015, 06:07 PM
On our 26fkws, the rear door would hang up on the top of the jam if my stab jacks were not deployed, soon as i put pressure on the jacks and got a slight lift on the rear of the tt it was ok, i took it in under warranty and the dealer adjusted the jam and haven't had any more issues
07 Silverado Classic 2500 HD
15 Flagstaff 26fkws Emerald Edition
08-06-2015, 12:59 PM
Yes, Jack up the stabilizer jack nearest the door real firm like above poster said and that will do the trick.
