Old 05-18-2018, 03:26 AM   #1
PuppyDogMom's Avatar
Manual Slide Extension
Hi. I have a Flagstaff 25BDS. I've been looking for a way to extend the slide manually in case I ever need to do that. I haven't been very successful in my attempt. Does anyone know how to extend the slide manually?
You did what you knew how to do, and when you knew better, you did better. --Maya Angelou
PuppyDogMom is offline   Reply With Quote
Old 05-18-2018, 04:37 AM   #2
fonzie's Avatar
Looking at this video, it looks like you have maybe under the floor system. Have a look under the entry steps outside and see if there is a protruding shaft for a manual handle.
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 05-18-2018, 06:07 AM   #3
If yours is like mine there is no extension or hole under the steps. You have to crawl under the unit and use a ratchet or power drill with a 3/4 inch socket to turn the motor shaft. It is readily visible.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
CedarCreekWoody is offline   Reply With Quote
Old 05-18-2018, 04:54 PM   #4
Thanks for the help. Next move is to head under the camper!
manual, slide
