Old 08-18-2019, 07:22 AM   #1
Manual Slide out
Silly question: I have a 2017 Forest River 25FKS Microlite. I am looking for the motor transmission housing for the slide out. Our battery has died and I need to crank it in. The Owners Manual is not helpful as not only does it not tell me where it is located, it doesn't even tell me what it looks like. Any suggestions?
ellisonpj is offline   Reply With Quote
Old 08-18-2019, 08:11 AM   #2
fonzie's Avatar
Have a look under the outside entry step if you have a shaft that comes out of the frame. If there is, here is a PDF file how to operate.
File Type: pdf Lieppert Electric-Through-Frame-Slide-Out-Manual.pdf (2.34 MB, 11 views)
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 08-18-2019, 10:13 AM   #3
Thank you! This was very helpful. Unfortunately the crank they gave us doesn't fit
manual, slide, slide out
