Old 04-23-2018, 01:13 PM   #1
Safetntx's Avatar
Max Water Pressure
We have a Flagstaff Micro Lite 21DS, and I would like to know the maximum recommended water pressure to allow in... I'm going to purchase the pressure adjustable regulator. Does anyone know the max recommended pressure? TIA
Tony Hill
Safetntx is offline   Reply With Quote
Old 04-23-2018, 01:24 PM   #2
PEX tubing is rated for well over 100 PSI.
The plastic fittings and some of the braided hose will likely fail before that.
There have been many discussions here on 'proper' pressure.
Most are in the 50-60 PSI category and some like 40 PSI.
I personally have my regulator set for 50 PSI.
I've never seen a need for anything higher.
Days Camped: '16=46 '17=30 '18=51 '19=50
pressure, water
