Old 11-19-2017, 03:47 PM   #1
Micro Lite 21DS Low Point Drain?
Brand new to RVing with our 2018 Micro Lite 21DS. We did our shake down cruise and camped for 3 days in NC. We love the floor plan and everything is worked fine. Now it's time to winterize it for the season.
I searched the threads, checked You Tube and I can't find a photo of what the low point drains look like. On the door-side of our RV, there's a label that says "low point drain", but underneath the Rv are three black hoses that come together in a T-style brass connector. Is that the low point drain? Shouldn't there be a red and blue hose sticking through the bottom of the trailer somewhere? I can't find them and the bottom of the RV is covered. Sorry for the noob questions. Thanks everyone.
Ox Brown is offline   Reply With Quote
Old 11-19-2017, 04:52 PM   #2
Who Dares, Wins
doc73's Avatar
I would say yes to the red and blue but with fr who knows. You'd more than likely have a fresh tank drain, then yes hot and cold low point drains. Usually, from what I have seen, the fresh tank is kind of on its own and the low point drains are right on top of each other.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 11-19-2017, 05:37 PM   #3
It's strange. I drained the fresh water tank. I looked all over the underside and can't see the drain tubes. I wondered if it was the three black hoses at the T-connector. Or maybe FR forgot to add the tubes?
Old 11-19-2017, 05:54 PM   #4
Who Dares, Wins
doc73's Avatar
Can you take a picture of the tubes?
2015 ChevyHD D-Max
Old 11-19-2017, 06:03 PM   #5
Tigger1's Avatar
We have the 2018 Rockwood 2104s which is supposed to be the sister to and built on the same line as the 21DS. Our low point drain lines, two of them not connected but separate and a couple of inches apart, are a couple feet behind the rear axle on the entry side of the trailer. I donít know what color they are but they have screw on black plastic caps. If you could enlarge our avatar you would see a label saying Low Point Drains where Iím talking about.
2010 Toyota Tundra DC SR5 5.7l
2020 Grand Design Imagine XLS 22MLE
2018 Rockwood Mini Lite 2104s
2014 Jayco x17z Hybrid
Tigger1 is offline   Reply With Quote
Old 11-19-2017, 06:03 PM   #6
It's actually 4 black hoses. Are they propane connections? These hoses are directly next to the "low drain" label. I tried to add photos, but maybe I don't have permission?
Old 11-19-2017, 06:20 PM   #7
Tigger1's Avatar
I have to reach under the skirting to access mine. They are behind the skirting and a few inches above coming out of the floor of the trailer. The first time I removed the caps I needed plyers to loosen them.
Old 11-19-2017, 08:41 PM   #8
I'll check again in that location. I hope I missed them.
Old 11-19-2017, 08:46 PM   #9
Mr. Dan's Avatar
If you have permission to post text, you have permission to post pics. See this.
Originally Posted by Janet H View Post
  • Click reply and scroll down to bottom of text box.
  • Click "go advanced" add text to message window and then scroll down.
  • Click "Manage attachments" A separate window will pop up.
  • Click "browse" Then select the file to be uploaded. Be sure that the photo is appropriately sized. 620 x 620 pixels (or smaller) and no more than 50K. Forums software will automatically reduce the size, but smaller size photos will upload much faster. You may select several photos to upload at the same time by repeating the last step.
  • Click "Upload" After pics have loaded close the pop-up window
  • Click "submit reply" to mount the text of your message - photos will automatically appear at the bottom of your post.
How to embed an image stored on another site:
You can do this by using image tags. Upload the image to a service like imageshack and then copy the URL of the image and put that between [IMG] tags. That will work well, as long as the host site stays in business and doesn't disable your image for overuse of bandwidth etc.
You can also paste in the location of a photo stored here in a photo gallery.
To do this: Paste the url of the image into your post. Then add the following code on either side of the url (with no extra spaces):
[IMG]url here[/IMG]
The image will appear where the url was in your text.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 11-22-2017, 09:14 AM   #10
Here's the two photos of the side of the RV and the hoses directly underneath the label.
ID:	156973   Click image for larger version
Old 11-22-2017, 09:22 AM   #11
Those hoses are for your propane supply.
Look farther back under the rig for something sticking down.
Something that would look similar to this...
Days Camped: '17=30 '18=51 '19=58 '20=21
Old 11-22-2017, 09:31 AM   #12
MillMitch's Avatar
different model but.....
we just bought our TT a month ago. the low point drains were inside the frame rail of the trailer (where the sticker was) and covered in foam. Had to lie on my back and bust some of the foam off to get the caps off. (you obviously don't want to knock too much foam off, it presumably keeps critters out)
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
Old 11-22-2017, 09:49 AM   #13
Tigger1's Avatar
Just crawled under and took this photo. The propane lines are on the right and the low drain lines on the left, red & blue. Maybe yours are not as obvious.
Old 11-22-2017, 10:49 AM   #14
Thank you for the replies. Looks like I'll have to crawl under the RV and have a much closer look.
Old 11-22-2017, 11:11 AM   #15
Mr. Dan's Avatar
Yes, if you haven't already crawled under it, you should. See the post above yours where Tigger1 gave you the best photo clue yet.
Old 11-22-2017, 12:58 PM   #16
I found them. They are tucked up under the fairing so far that the only way to see them is to lay under the trailer. Thanks everyone.
Old 11-22-2017, 01:59 PM   #17
Who Dares, Wins
doc73's Avatar
Good you found them thanks for the update.
2015 ChevyHD D-Max
Old 11-22-2017, 02:06 PM   #18
bikendan's Avatar
That's pretty common with a lot of RVs.
Equalizer WDH
drain, lite
