Old 09-23-2013, 02:15 PM   #11
Yes, please let us know if it was the fuse and where it is and what kind of fuse. I have a 2014 21FBRS and don't want to have to hand crank the slide.
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 09-23-2013, 07:46 PM   #12
Yes, I have a 2014 21fbrs and would like to know where the fuse is as well
frankchmi is offline   Reply With Quote
Old 09-24-2013, 08:43 PM   #13
Broke and happy
bobfa's Avatar
Me three. Thats why we read these forums.
bobfa is offline   Reply With Quote
Old 09-24-2013, 10:36 PM   #14
Look in the storage compartment by the water pump. I believe I saw a fuse holder near there when we cleaned out the storage compartment earlier this year.
2006 Ford F150
2012 Flagstaff 21FBRS
Scouter is offline   Reply With Quote
Old 09-25-2013, 10:53 PM   #15
genecusano's Avatar
There is a 30 amp inline fuse on the inside of the frame directly under the storage compartment. Easy job, but wounder why the just didn't put it in the box where the panel is for all other fuses are.
Gene & Betty
2011 Silverado
2013 Flagstaff Micro Lite 21 FBRS
Mission, TX
2013-100..2014-180..2015-175..0
genecusano is offline   Reply With Quote
Old 04-21-2014, 01:05 AM   #16
Follow the red wire coming from the battery under the A-frame front of trailer directly under the storage compartment you will find a red fuse holder, remove the fuse cover replace the 30amp fuse with a new 30 fuse and your slide out will work fine.
bmwbikr1 is offline   Reply With Quote
Old 06-10-2014, 09:30 AM   #17
Just wanted to confirm same problem with 2015 Micro-Light RBS 21 slideout. Just as Gene and Betty had, we returned from a 10-hour drive with a brand new 21RBS, extended the slide to clean the floor from our first weekend's camping. When we attempted to retract the slide, nothing happened. We did a search on this forum and found this thread. As suggested, I found the red line off the battery, followed it to an inline fuse under the body below the storage comparment. There I, too, found a blown fuse. I replaced the 30-amp fuse and retracted the slide. Moral. If the slide don't work, check the inline fuse first. Thanks for the thread.
MediaProf is offline   Reply With Quote
Old 06-22-2014, 08:20 PM   #18
I had the same problem this week. Replaced the fuse and everything is working fine now.
jaroberts2356 is offline   Reply With Quote
Old 06-22-2014, 10:12 PM   #19
Slympicins's Avatar
We too had the same issue. We keep a good supply of fuses on hand in the TT. They come in handy.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 07-08-2014, 05:32 AM   #20
cecelea's Avatar
This is great to know! In our old trailer we thought it was the crank motor that went bad, never checked for a fuse. Makes sense!
cecelea is offline   Reply With Quote
