Old 07-08-2014, 07:20 AM   #21
We should all remind ourselves that the more strain on a motor the greater the current draw and the greater the current draw the more likey the fuse will do its job ...
I make sure that we don't keep the finger on the switch after the slides have just touched the wall and now I don't bring my stabilizers up hard against the frame when retracting.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Edition | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra SLE 5.3L | K&N filter | Hypertech Max Energy tune | Prodigy P3
Wmoses is offline   Reply With Quote
Old 07-08-2014, 11:36 AM   #22
Slympicins's Avatar
I like my slides tight agains the wall but I do I just barely touch the top when retracting the stab jacks.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Slympicins is offline   Reply With Quote
Old 07-26-2014, 07:13 PM   #23
Out again last week, blew another fuse retracting the slide on my 21 fbrs. That's two in 6 retractions...if you're counting!
MediaProf is offline   Reply With Quote
Old 07-26-2014, 07:31 PM   #24
If a fuse is blowing repeatedly there is probably a reason other than the motor straining. Possibly worn insulation that causes a short somewhere.
SuwanneeDave is offline   Reply With Quote
Old 07-27-2014, 09:38 AM   #25
You may wish to check out this post:
08-06-2013, 2109S Slide Motor Pulled Loose, posted by lswartz
Check out the photo in post #6
Before I installed a brace under the slide motor on our 21FBRS it would rock up and down about 2". With the slide pulled in the motor would rotate down onto the blue/cold water line, and probably gone to the floor if the line didn't block it. With the slide extended the motor rotated up about 2-3/4" above the floor.
That is the height of the brace I installed.
Thanks to lswartz and others for pointing out the problem/solution.
Henboy is offline   Reply With Quote
