The red and white are left and right audio. The yellow is the video feed. If it isn't plugged in than that is the problem. If you get a cable and plug it in, then set it to the correct source it should work. If not, there is one of three problems, bad tv at plug in. Bad DVD player or bad yellow cable.
2018 Rockwood Premier 2516G
2014 Nissan Titan
“Always do what’s right; this will gratify some and astonish the rest” – Albert Einstein
