Sorry 25FBLS not SL.
So we get our new Micro Lite home and I begin the task of cleaning and tweaking all the little issues most trailers have when new. You know like cleaning out all the construction debris in the various nooks and crannies. Spray foaming any possible critter point of entry and in general fix what ever made it past the manufacturer or dealer inspection.
So after cleaning and sealing inside the trailer I go to the front pass through to clean construction debris from behind the bed panel and discovered that not only the floor of the pass through is not insulated neither is the ceiling and shared wall to the bedroom. Add to that the “drop frame pass through” has a 3/8-1/2” gap between the storage area and the under side of the trailer in the corners which are hidden by the bed panel.
I’m thrilled with the huge pass through storage on this model but very disappointed and perplexed that Forest River/Flagstaff did not properly design and build the storage area to keep weather and rodents from accessing the storage area and some type of insulation to provide a barrier to heat or cold under the bed. They also used unprotected interior wall board as shims where the gaps were under the trailer.
My solution was to foam the two gaps, trim the exposed interior wall board off and seal the surface with a spray on rubber. We’ll see how that works.
Since the storage area is directly below our bed I insulated the ceiling of the storage area and the adjacent wall with some R-4 styrofoam insulation and reinstalled the decorative wall board.
Hopefully these steps will keep critters and the weather out and provide for a more comfortable living/sleeping space.
Just wanted those that have the 25FBLS or Rockwood 2511s or that are considering either of these to be aware.
