Old 06-22-2018, 05:16 PM   #1
Microlite 21ds pulled by Ford Explorer Sport
So we are wanting to visit Colorado Springs from Ruidoso Downs New Mexico, and well this will be our for real long road trip with our 2018 micro-lite 21Ds being pulled by our 2017 Ford Explorer Sport. Can anyone please tell me if this is a good idea?? Iíve been told many different things, like the hills are too steep, and the SUV will struggle, and itís too much too handle. Has anyone done this trip before? Do you recommend any specific highways?
ShortyMc40 is offline   Reply With Quote
Old 06-22-2018, 05:33 PM   #2
bikendan's Avatar
Give us the Exploder's specs.
Factory tow package or not
Ecoboost or not
Rear end ratio
Equalizer WDH
Old 06-22-2018, 05:50 PM   #3
Ecoboost or not
Rear end ratio
Ecoboost yes
Factory Tow package
AWD
Old 06-22-2018, 05:51 PM   #4
Blackrock's Avatar
We need a lot more information than you have provided. Like how is your Explorer equipped. Engine size and do you have the HD tow package. Also what does your door sticker say as to payload rating.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 06-22-2018, 05:52 PM   #5
Originally Posted by ShortyMc40 View Post
Ecoboost yes
Factory Tow package
AWD
5,000 max towing capacity
Old 06-22-2018, 05:58 PM   #6
Blackrock's Avatar
If you have the 3.5 V6 eco boost and the heaviest package then you are right at the limit with this trailer.
Old 06-22-2018, 05:59 PM   #7
Scoundrel
HangDiver's Avatar
The drivers side door jamb of your Explorer will have a yellow sticker that will list the payload or cargo capacity of the vehicle. The others above will need to know that number to be able to advise you properly.
Welcome to the forums and to Colorado if you make the trip.
Rich J.
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 06-22-2018, 06:05 PM   #8
Flybob's Avatar
That is a marketing number. Need to know cargo/load capacity from sticker on drivers door
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-22-2018, 06:31 PM   #9
Rich J.
Old 06-22-2018, 06:33 PM   #10
Originally Posted by flybob View Post
that is a marketing number. Need to know cargo/load capacity from sticker on drivers door
ID:	176884Click image for larger version
Old 06-22-2018, 07:18 PM   #11
Scoundrel
HangDiver's Avatar
Others more knowledgeable than I will chime in, but I would not tow that camper to Colorado with the Explorer. The online specs for your Microlite 21ds show 4,500lbs dry weight as it came off the assembly line. Add propane, batteries, food, water, etc (Micro-Lite 21ds has a 1,500lb payload) and suddenly your towing a 6,000lb camper with a tongue weight of almost 800lbs. That leaves only another 400lbs available for the contents of the Explorer (driver, passengers, other gear). Essentially you would be over taxing the engine, transmission, and axles.
Its a nice camper, just not a good fit for the Explorer.
Old 06-23-2018, 12:59 AM   #12
bikendan's Avatar
Yep, not workable.
The 21DS's fictional dry tongue weight already exceeds the Explorer's 500lb max hitch weight, before you add battery, water and cargo.
And loaded for camping, the 21DS will exceed the 5000lbs max towing capacity.
Equalizer WDH
Old 06-23-2018, 05:14 PM   #13
I use the same vehicle (Platinum, but same engine and tow capabilities) and live in the Sierra, so whenever I move there’s passes and mountains. It runs extremely well, the engine is very powerful even uphill and the automatic sway control works. But... my trailer is a Wolf Pup 16FQ, which has an empty weight of 3,200 lb, and even with full load (well, almost, haven’t tried with full water tank yet) is within the 5,000 max towing. Would I sometimes like to have a larger trailer? Yes. Would I want to TOW a larger trailer with the same tv? Meh...
iconnekt is offline   Reply With Quote
Old 06-23-2018, 05:17 PM   #14
Towing Micro Lite 21DS
We haul a 2018 Micro Lite 21DS... empty weight of that trailer is just under 4,600 lbs empty.... watch your loading..
thom125 is offline   Reply With Quote
Old 06-25-2018, 09:18 AM   #15
Thank you so much for all your responses and advice.
ford, led, lite, sport
