Old 05-04-2014, 07:57 PM   #1
want a Cat 293REX
Question MicroLite 21FBRS question
Thanks again for your time! Members here are great!
Question on the water filter. Has anyone had a need to replace the O Ring or Gasket on the filter housing? How do you know when to replace this part?
where did you buy it/part number/etc?
Thank you!
boatless is offline   Reply With Quote
Old 05-04-2014, 09:32 PM   #2
Slympicins's Avatar
Thank you!
Boatless read my experience with my water filter. The canister slowly backed out of the housing and flooded the TT a little (only because I happen to be standing close and shut the water off). I cut out the water filter and installed a bypass hose. If you want a filter I would suggest a filter outside on the hose bib. Water in your TT is NOT your friend!!!
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 05-05-2014, 02:38 PM   #3
want a Cat 293REX
Thanks, we'll read about it.
