Old 07-04-2013, 05:45 PM   #21
LA-Fox
LA-Fox's Avatar
We put plumbers putty along the caulk line above the shower pan, added a corner water leak guard (from lowes), caulked around it and changed the shower curtain to a plastic one. It didn't leak last night as it had during usage prior to these changes. It's a temporary fix, but working for us at the moment.
Angela and Lori
2014 Micro-Lite 21fbrs
2003 Ford F-150 Lariat Supercrew 5.4L
LA-Fox is offline   Reply With Quote
Old 07-07-2013, 06:13 PM   #22
I had water get behind the toilet the first time out, but the camper was not quite level and leaning toward the toilet. We replaced the shower curtain with a heavier one from Wal-Mart. I also caulked in a plastic triangle piece from Home Depot. The last time out, I left it a little unlevel leaning toward the drain and had no water get behind the toilet.
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 07-29-2013, 08:45 AM   #23
uphillracer's Avatar
We just got back from a five dayer, the first since our improvements. All the work paid off. High and dry. I suggest caulking the space between the BR cabinet and the shower tub as well as caulking all around the shower walls. A new "regular" shower curtain worked and didn't turn off the fan during showering. Finally, an Oxygenics shower head was the piece de resistance. We did remove the flow restricter at the screw-on connection point. GREAT shower now!
uphillracer is offline   Reply With Quote
