Old 06-24-2013, 10:32 AM   #1
want a Cat 293REX
Unhappy MicroLite 21FBRS - shower help please!
Back to report and need help! We just returned from 3 days at a state park and I took the first shower. I made sure the shower curtain was covering the edges but wow - when I got out - there was at least 1" of water behind the toilet and on the floor. Something is very wrong - how did this happen? Thankfully, a good floor and a good towel - very upset!
What happened, is this a leveling problem? The drain is not plugged and the gray water filled up quickly - 3 days - full and drained properly.
Help please!
boatless is offline   Reply With Quote
Old 06-24-2013, 10:46 AM   #2
We had something similar happen in ours, too. Since this happened in our 2109S, we always put a couple of extra towels along the floor at the edge of the shower.
We have also found that placing our backs to the outside wall (same side as the bath sink is on) gives us a little more room and we can visually see if the bottom of the shower curtain has been moved to outside the shower pan. We haven't had any water outside the shower since we started doing this.
Another recommendation I've seen from others here is to replace the shower curtain with one that has magnets (for weight) along the bottom.
NanaKaren
Karen Elling
2012 Rockwood Mini Lite 2109S
Useta have a 17 ft Casita LD twin bed mod &
Coleman pop up
NanaKaren is offline   Reply With Quote
Old 06-24-2013, 10:54 AM   #3
mjones12's Avatar
We had the same problem in a previous camper, a Surveyor 186. Floor was covered with water after the first shower. We got two triangular plastic pieces from Lowe's and caulked them into the two bottom corners of the shower. Never another problem.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is online now   Reply With Quote
Old 06-24-2013, 12:30 PM   #4
2012 Micro Lite 21 FBRS
Guapotims's Avatar
Help please!
We also have a 21FBRS. I noticed (the last time we camped) that water was running along the "flange" (upper part of the basin) on the rear side of the camper. Unless there is a slight lean toward the back left corner of the TT, water will run off the flange onto the floor behind the toilet. Some type of diverter could be glued and caulked on top of this flange to divert the water back into the basin. Hope I've explained myself correctly.
Here is a picture with "A"representing the Flange and "B" representing the flow of water behind the toilet Hope this helps
http://www.forestriverforums.com/for...cture7876.html
2012 Flagstaff Micro Lite 21 FBRS
Guapotims is offline   Reply With Quote
Old 06-24-2013, 04:53 PM   #5
want a Cat 293REX
Diverter - splash guard coming up!
Many thanks!
Old 06-24-2013, 07:54 PM   #6
Guapotims's Avatar
No problem! Good Luck with your project!
Old 06-25-2013, 08:00 AM   #7
Just caulked in a plastic triangle in the corner by the toilet this weekend in my new 21FBRS. Also replaced the shower curtain with a thicker one from Wal-Mart. I still plan to keep a towel down when showering though.
One tip on the showering, put your back to the corner of the shower and hold the sprayer in front of you. That way you are always spraying into the corner and not against the curtain. Works for me anyway.
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 06-25-2013, 09:49 AM   #8
Just another thought....that gray water tank will fill up faster than you think while enjoying your shower- then it will back up at the drain, and run out onto the floor.....
U get the picture, it has happened to us.....(not me, though) Randy
Old 06-25-2013, 09:58 AM   #9
Shower Fixes in 21FBRS
Replaced the shower curtain with one heavier duty, wider and longer. I cut the bottom so it just touches the shower pan.
Also, installed two of the plastic tub/shower guards from Lowes. Used clear silicone caulk and had to cut-out a piece so it would seal up against the sink vanity top.
Finally, make sure the TT is level, as water will sit in the pan.
___________________________
2012 F-150 Ecoboost, SC
2013 Flagstaff 21FBRS
2010 Trailet New Yorker, 2-Horse
HorseyHauler is offline   Reply With Quote
Old 06-26-2013, 08:48 PM   #10
uphillracer's Avatar
We experienced this too. First, the stock shower curtain is not weighted and too short. Second, you will sese a gap between the shower tub and the sink cabinet. We just SEVERELY caulked that interstice and also caulked all the sides. Next, we bought a regular shower curtain with magnets (for weights) on the bottom. I expect we will not have a problem anymore. Also, I had to go and re-level the TT as I found it 1-2 degrees slanted towards the front. That isolated any water in the BR. Make sure you don't run the exhaust fan while showering. With the new curtain I'm not as concerned anymore.
uphillracer is offline   Reply With Quote
Old 06-27-2013, 09:48 AM   #11
genecusano's Avatar
Shower Mod for 21FBRS
We added splash guards from Lowe's. Also if you pull 2 of the shower hooks to the wall on each end. Then when you shower, turn around with your back in the corner sow the water points the back wall. We never get water anymore. Hope this helps. As soon as I figure out how to upload, I will post picks.
Gene & Betty
2011 Silverado
2013 Flagstaff Micro Lite 21 FBRS
Mission, TX
2013-100..2014-180..2015-175..0
genecusano is offline   Reply With Quote
Old 06-29-2013, 07:40 PM   #12
Are the curtains in these campers standard length? Where did you get your new curtain from? I'd like to try something like this in my Rockwood 2109S.
GearHd6 is offline   Reply With Quote
Old 06-29-2013, 09:17 PM   #13
Shower curtain from Walmart super store.
Old 06-30-2013, 03:08 PM   #14
Shower leaking
Help please!
The problem I had was similar and it's not the curtain. When leveled improperly, the water runs down the wall and along the top of the shower basin and out onto the floor. I put caulk on the top of the shower basin channeling the water back into the basin. Just two angled lines of caulk
on the top of the basin at the end where the shower wall stops. Problem solved.
Jersey Copper is offline   Reply With Quote
Old 06-30-2013, 04:08 PM   #15
There have been many good ideas presented. I'll let y'all know how our caulking and shower curtain fix works after out next trip towards the end of July. This is obviously a design flaw and I will look for some way to convey it to FR. There must be many more of use experiencing this.
Old 07-03-2013, 05:35 AM   #16
LA-Fox
LA-Fox's Avatar
Exhaust fan
Someone mentioned not to run the exhaust fan while showering... Does the exhaust fan have a connection to the 21fbrs shower leakage problem? We just bought our unit and, we have the same problem...
Angela and Lori
2014 Micro-Lite 21fbrs
2003 Ford F-150 Lariat Supercrew 5.4L
LA-Fox is offline   Reply With Quote
Old 07-03-2013, 06:38 AM   #17
JohnF's Avatar
So could leveling the camper solve the whole problem?
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
Old 07-03-2013, 07:03 AM   #18
Guapotims's Avatar
I don't believe a shower curtain is a fix for this problem. Water is running along the top of the basin. A shower curtain cannot reach the top of the basin to stop the water.
also, I was told to use the Fantastic Fan "everytime" I showered to keep the humidity out of the trailer. I cannot imagine why you wouldn't want to use it. The only time you shouldn't use the fan is when flushing the toilet. Gas from the septic system would be drawn into the carriage.
Old 07-03-2013, 07:07 AM   #19
Guapotims's Avatar
I think you could stop the water from flowing behind the toilet if you actually lowered this (bathroom) corner a bit.
Old 07-03-2013, 08:28 AM   #20
We have completely caulked around the shower basin. There was a large interstice between the sink cabinet and the shower basin. Also it did not seem well sealed all along the shower walls. We also added a long and weighted shower curtain. We go out in 2 weeks and we'll field test our repairs and let y'all know what we experience. We found the exhaust fan pulled on the flimsy original shower curtain. Now with a more substantial one we'll shower with it on and see what happens.
