MicroLite 21FBRS Slide issue
When extending the slide on the MicroLite 21FBRS, it tilts up, slides then tilts back level once it is fully extended. Mine is now extending fully and meeting the wall at the bottom but there is an inch gap at the top now like it doesn't finish the tip back down on the extention. I checked the manual. It makes it sound like there is an adjustment for this. Does anyone know what this adjustment is and how to do it. I can still use it and it slides back in fully.
If it's an easy adjustment, I would like to do it. From the outside you can definitely see that it hasn't tipped all the way out at the top.
If someone can explain how the tip/slide process works on this unit, I would like that too. I can't see how it does the tip..thanks!
2014 Flagstaff 21FBRS
2013 Toyota Tundra 5.7
