Dry lube only, if you use any kind of grease on the track it will pick up dirt a destroy the gear. Slide the slide out all the way and clean the track of any metal filings from the track. I found a lot when I purchased mine new. Also my rubber seals and track we're not lubed from new so do this ASAP .
Forest River uses 3-4 different slide systems. My old trailer used hydraulics where my new trailer is electric. Ask your dealer which lube is required for your trailer.
SPARKEY BOB
IBEW LU 613 Atlanta
Micro Lite 21 FBRS
Toyota Tundra
