Old 05-14-2018, 06:10 AM   #1
OswegoLion's Avatar
Molding on the side of 2 slides pulled apart!!
Molding has pulled away on both sides and needs to be re secured. The staples pulled away. A few of the experts on here may be able to give me a suggestion! My thoughts are wood glue, small screws or re staple! Not sure how to do the staple solution or what I would need. Model 8528 IKWS!!!
OswegoLion is offline   Reply With Quote
Old 05-14-2018, 09:08 AM   #2
SeaDog's Avatar
I don't think i would use the wood glue but that just me. The last one I fixed I used a pin nailer and angled the nails to hold better. small screws may also work and paint the heads to match the wood.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 05-14-2018, 09:52 AM   #3
OswegoLion's Avatar
Never used a pin nailer before!! Where would I get a cheap one since this may be only use! Size nail recommended!!
Old 05-14-2018, 11:39 AM   #4
SeaDog's Avatar
you may be able to find one at Harbor Tool and Freight I use 18ga pin nails
Retired Navy
Old 05-14-2018, 11:46 AM   #5
Head Rambler
Can you post a picture of the problem? It will help us identify the correct method of re-securing the trim.
If it's just appearance trim then some narrow crown staples would do the job. You can find those at Harbor Freight. If it's the inside frame around the slide, then you need something more robust to hold it on.
Gotta go campin!
Old 05-14-2018, 12:10 PM   #6
I used a 18 gauge brad nailer to put my trim back up got it on Amazon for $29 ....use 1 inch nails you will need a 100 psi compressor also used 2 or 3 “dots” of adhesive to help keep it there.. I am assuming you’re talking about the inside
rarobo is offline   Reply With Quote
Old 05-14-2018, 12:25 PM   #7
Had same problem with corner moldings on our Rockwood 2608ws stables pulled out. Had the moldings testable at international rally new stables came out again by the time we got home. So I super glued each stable and pushed back in holes and haven't had the problem in two years and 15000 miles of driving around country. Good Luck with what you decide to use. The best way to fix it is do it your self is my Moro when possible.
2013 Rockwood 2608ws
2013 Ram 2500 4x4 mega cab 5.7 Hemi
US Air Force. Msgt retired
Joe-Barb is offline   Reply With Quote
Old 05-14-2018, 02:53 PM   #8
satdog01's Avatar
Had issue with molding on floor in front of 2017 Flagstaff 832OKBS. Had tech repair it with longer nails at an angle at Goshen Rally. Seems they used fasteners that where to short possibly.
2020 Georgetown 31L, Safe T steering, Onan Geny
2015 GMC TOAD w/Blue Ox tow plates
Pepper 🌶 Pomeranian rescue 327 nights as camping buddy
Days camped in FR, 2011-12 = 77, ‘13-14 = 98, ‘15 = 52
‘16 = 77, ‘17 = 81, ‘18 = 44, 19’ = 83, 2020 =
Retired :
satdog01 is offline   Reply With Quote
led, mold, slide
