05-12-2019, 08:13 AM
Mount Toilet Paper Holder
I guess mounting the Toilet Paper holder does not come standard when buying a new E-Pro 19FBS and I have to do it myself.
I am getting ready to do this, just have a little reservations drilling into my camper walls. Anyone have any advice before I do this?
Thanks;
Dustin
05-12-2019, 08:24 AM
"Wall Anchors" or mount to a more solid surface. The walls are about an 1/8" to 3/16" thick and do not hold screws very well. I was fortunate to be able to mount ours on the side of the sink where I could get the screws into the 1x2" frame of the sink.
05-12-2019, 08:35 AM
I mounted mine to side of sink cabinet and cut little pieces of 1 x 2 and put inside cabinet as a backer for the screws to screw into.
2019 Flagstaff Microlite 25LB
2021 Silverado 3500 HD CCLB
2018 Escalade ESV
2009 CTS-V
05-12-2019, 08:39 AM
05-12-2019, 08:41 AM
Adhesive works well, 2 years and still holding good.
05-12-2019, 08:44 AM
Originally Posted by cardwellmarty
X2, this one has held solid for 3+ years!
Carmen and the pack
2015 Coachmen Clipper 17BH
2017 Dodge Durango Citadel 5.7 Hemi
Canadian Member
We use a fee-standing toilet paper holder similar to this.
05-12-2019, 10:38 AM
We too screwed ours to the sink cabinet, didn't do the little wood blocks mentioned above, but will go back and do that!! As for the towel rack, we put it on the wall beside the med.cabinet used provided screws after removing one from soap dish to confirm same length and screw
05-12-2019, 10:49 AM
I try to find a stud using a stud finder for at least one side of anything I mount to a wall then use wall anchors on the other side. Cabinet framing works well also.
2020 Chevrolet 2500 LTZ, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart.
05-12-2019, 11:10 AM
Pop Rivets might work as well.
We use a free standing one.
Mike
TV = 2017 Ram 3500 (aka FRAM)
5er = SOB (2019 Grand Design Reflection 367BHS)
05-12-2019, 11:39 AM
You've received good advice about mounting so I'll say something about your comment of the the factory not installing the holder.... the factory doesn't mount these things (TP holder, soap dish, towel rack, etc) as everyone has their own ideas of where they should be placed.
I'd sooner mount them, than stand there thinking... "why the heck did they mount that thing there?"
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=64
05-12-2019, 11:45 AM
We keep ours in the cabinet under the sink. Don't need to mount anything.
05-12-2019, 11:53 AM
3M Self Adhesive Toilet Paper Holder,Bathroom Tissue Holder(5.0 inch),Wall Mount
$8.99 from Amazon
Mark & Heather
Mountain Falls, VA
2019 Salem FSX 179DBK
05-12-2019, 01:20 PM
3m tape
We use a holder that has been mounted using 3M tape. Excellent method. Been in use for over 1 year. I bought the one in the link.
https://www.amazon.com/YIGII-Toilet-Paper-Holder-Stainless-Steel/dp/B07K2WLJMY/ref=mp_s_a_1_14?keywords=toilet+paper+holder+with+ 3m+tape&qid=1557684609&s=gateway&sr=8-14
05-12-2019, 01:36 PM
Erinn
I "saved" ours, & purchased a self-adhesive one at Amazon - works great!
amazon.com/gp/product/B00LRH18BU/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Dan and Erinn
2018 Forest River Sunseeker 2420MS
TOAD: Mercedes Smart Car
06/01/18-11/10/18 Camped 43 days!
05-12-2019, 01:42 PM
Camping with Labs
Lots of good suggestions from the forum, as usual. I mounted our toilet paper holder onto the side of the vanity, next to the shower enclosure, using stainless machine screws, flat washers and nuts. It's out-of-the-way, yet easy to reach. The bathroom does not appear overly small; however, there were not an abundance of options for mounting the holder - so this works fine. But back to your original question about drilling into an outside wall. Yes, find a stud if possible. Measure carefully. Highly recommend using a collar on your drill bit to ensure you don't accidentally create the perfect place for an outside sticker or fake vent (sure, ask me how I know) on the exterior of your RV. Then place a long thin nail or similar object into the hole to determine the depth for that location. There is usually some foam insulation in the outside walls, and there could be electric wires, etc. so be gentle and cautious. Now you can decide the best connection method to use, and you'll know what length screw, machine screw, toggle bolt, metal EZ anchor, etc. you can use. In this case, a little shorter may be a little better. I've used all of those fasteners at one point or another, and all have worked well, but I try to choose wisely based upon weight of object being attached and intended utilization. I admit I've never tried rivets, but it sounds like a fantastic idea and I'll definitely give that a try as well. Good luck, and don't forget the National Parks sell some nice stickers in case you can't resist adding exterior decoration to your RV
Chris, Paula, & camping Labs, Shasta (RIP 8/10/20) & Cammie
2005 Yukon XL 2500 with 8.1 Engine, Allison Transmission, and 3.73 Axle Ratio
2019 Rockwood Signature 8335BSS with Hensley Arrow Hitch
05-12-2019, 01:44 PM
A little more work, but less space.
I used a recessed holder that went into the vanity. Takes up less space in doorway. Got it at a garage sale for a $1.00.
Prime Time Manf. Crusader 270RET 2012
Ford F150 5.4L B&W Companion Hitch
updated to Andersen Aluminum Ultimate Hitch 2017
05-12-2019, 02:02 PM
Hi all! We stained a thin piece of wood to match the cabinetry, cut just larger than the paper holder mounting base, as a backer. We attached it to the inside of the door beneath the sink with glue and screws, being careful to use the right screw length. This keeps the TP roll dry & safe from sink or shower splashes, it's discreet, and looks nice.
New pup Tawas, yellow lab
2013 Roo 23SS, Toyota Tundra SR5, Crew Cab
days camped: Never enough!
05-12-2019, 02:06 PM
Same here... convenient at knee level.
05-12-2019, 02:07 PM
X2
Jim & Evelyn Tatum
2023 Columbus River Ranch 391MK
2022 Dodge Ram 3500 Big Horn Diesel
Nights Camped 2023 = 30
Nights Camped 2022 = 40
