Old 07-19-2011, 08:23 PM   #1
Newly retired and ready
Mounting Small TV
Just picked up my 5th wheel Flagstaff 8524RLS and would like to mount a small 19inch LCD in the bedroom. The wall where the shelf is now located does not appear to have any interior support to screw a bracket into. Anyone have any thoughts or ideas
Gl111349 is offline   Reply With Quote
Old 07-19-2011, 09:47 PM   #2
Nigels's Avatar
If you have the useless TV shelf that we have, which just gets in the way even when folded then those brackets holding that shelf must be screwed into something reasonably strong. If we are talking the same thing then cannot your LCD brackets be screwed into the same place as the shelf brackets?
Nigel & Bev
Brit Driver & Canadian Naviguesser
We summer in Cowichan Valley BC Canada & winter in Monchique Portugal great camping in both!
2011 Rockwood Signature Ultra Lite 8280ws 2011 Dodge Ram 3500 4x4 Diesel 2000 Honda S2000
Nigels is offline   Reply With Quote
Old 07-19-2011, 09:53 PM   #3
I mounted my 19" flat screen to the wall on a universal swing arm using three, 5/8 diameter by 1 inch long lag bolts and have towed over 1400 miles without even a hint of it coming loose. Just be carefull not to use too long of bolts cause the wall is not very thick at all.
wfkssvlite is offline   Reply With Quote
Old 07-20-2011, 05:26 AM   #4
Then lag bolts it is. I was thinking that direction but wasn't sure if the panneling would hold up. Thanks for the reply this forum is worth it's weight in gold.
Old 07-20-2011, 06:30 AM   #5
RV Newbie
buzzards27's Avatar
The paneling alone will not safely support the bracket. You need to hit framing behind the panel. If you cannot hit solid wood at the location you want you might install a horizontal board between two studs on top of the paneling. Make the board wide enough to accommodate the bracket.
2005 FR Lexington 210 6.0L 8500 miles
2007 2500 Silverado Ext. Cab, 6.5' bed 5.7L
2010 Ford Fusion Hybrid
1963 Ford 861 5 speed with loader
1958 Ford 800 Select-O-Speed (parts tractor)
buzzards27 is offline   Reply With Quote
