Old 03-16-2013, 04:43 PM   #1
Question Murphy Bed
I know this may seem like a dumb question but how do you get the bed to go back up? I am a woman maybe I'm not pushing up hard enough or what afraid I will break something. Micrrolite25KS Camper brand new camper just getting it ready for spring break.
Nascar99 is offline   Reply With Quote
Old 03-17-2013, 10:25 AM   #2
Lift it straight up from the end It will go back in place.
STL-UltraLite25KS is offline   Reply With Quote
Old 03-17-2013, 10:31 AM   #3
Crusader's Avatar
Carl Edwards !!!!!!!!!!!! 48 my first pick... the 99 always my back-up man
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 03-17-2013, 11:45 AM   #4
Yes I am a Carl Edwards fan hope this year is better than last so far it is.
Old 03-17-2013, 12:20 PM   #5
timarti's Avatar
Ours will go up with just a light lift on the bottom of the frame. DO NOT PUT FINGERS IN THE HINGED AREA AT THE TOP OF THE FRAME! If it does not go up easily, there may be a problem with the shocks on the sides that control the travel. Once you start it , the bed should pretty much go up on its own.
Tina & Ted & pooches
2012 Ford F-150 XLT 5.0L V8 4x4 with tow package
Andersen WD hitch with sway prevention
2012 Rockwood UltraLite 2304s trailer
timarti is offline   Reply With Quote
Old 03-18-2013, 06:32 PM   #6
there is a release knob that you have to pull. Mine is on the rights side at the cabinet
SuwanneeDave is offline   Reply With Quote
Old 03-18-2013, 06:45 PM   #7
wolfpack21643's Avatar
I have the Murphy bed in my Mini Lite and I have never seen a knob of any type. I assume we have the same bed? I also have never had any problems putting it up, but I did read a post on here last year where some one could not get theirs up and when they discovered the problem it was because the anchor bolts that hold the pivot area together had pulled loose from the wall.
2013 Rockwood Mini Lite 2306 w/Murphy Bed
2004 F-150 4.6 Liter 4x2 Factory Tow Package
2012 - 21 Nights Camped
2013 - 21 Nights Camped
wolfpack21643 is offline   Reply With Quote
Old 03-23-2013, 08:16 PM   #8
Maybe it is a difference between the mini and micro or a recent addition, but mine definitely has a release knob that has to be pulled.
Old 03-24-2013, 10:01 AM   #9
Are you talking about the 2 slide locks on each side of the bed to hold the bed up while traveling?
Old 03-30-2013, 04:32 PM   #10
No it is definitely a release.
Name:	release handle.jpg
Old 03-31-2013, 05:29 PM   #11
I dont have that. Do you have two slide locks that hold the bed up?
Old 03-31-2013, 06:21 PM   #12
FloridaPhil's Avatar
My mini lite has a cord behind the head of the bed. You have to pull on the cord and at the same time lift the bed
FloridaPhil is offline   Reply With Quote
Old 03-31-2013, 07:19 PM   #13
huh, they must have made a pretty major change for some reason.
Old 03-31-2013, 08:27 PM   #14
Probably people forgetting to engage the side locks before towing.
Old 03-31-2013, 08:52 PM   #15
I could see that. But I dont think mine would fall down even if I forgot the two latches. Mine is pretty stiff going up and down but then again it is pretty amazing to see what is moved around the TT after a long tow.
Old 04-22-2013, 09:45 PM   #16
Mrpsyko's Avatar
My 25KS does not have a release knob like you are showing either, the Murphy bed just lifts up. But watch them fingers at the top.
Mrpsyko is offline   Reply With Quote
