Old 11-29-2011, 01:28 PM   #21
DDC
DDC's Avatar
I never hear any noise from my Hensley.
DDC is offline   Reply With Quote
Old 11-29-2011, 01:34 PM   #22
For $2000 I'll put up with a little groaning now and then
Len & Cheri is offline   Reply With Quote
Old 11-29-2011, 01:36 PM   #23
alageezer's Avatar
My thoughts exactly.
2012 Signature 8285WS
2010 Ram 2500 w/Cummins
alageezer is offline   Reply With Quote
Old 11-29-2011, 01:52 PM   #24
GASPEDDLER's Avatar
I use the Equalizer and do experience some noise at slower speeds. Only really noticeable while driving through the camp on the way to the campsite as I like to roll down the window. Nothing excessive but it happens. I will say it is a joy to use and makes the tow more enjoyable. Highly recommended.
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 11-29-2011, 01:59 PM   #25
MilCop4523's Avatar
The Hensley although never having a recorded upset was closer to 3500 for what I wanted.
I don't plan on doing pilons on the highway with my trailer and between the sway control on my 2011 Ecoboost and the Reese dual cam weight dist system for 591.00 delivered to my door I think that at 55 to 60 miles an hour (cause I'm in no big rush to get where I'm going safely) the Hensley was a bit over priced.
But their owners seem to love them!
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is offline   Reply With Quote
Old 11-29-2011, 02:16 PM   #26
Fire Instructor's Avatar
Except for the whimpers from the depleted wallet!!!
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 11-29-2011, 07:26 PM   #27
bikendan's Avatar
x3!
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 11-30-2011, 05:51 AM   #28
This was my set up.
I would like to bring one issue up and this is something you might want to think about.........Your reciever has two weight ratings, one rating is with out weight distribution and the other is with distribution. I called Reese about this years ago and the Engineer said that this was the first time anyone has ask this question, and the question was.....If I were to remove the spring bars on my hitch system and back the camper could this cause damage to the receiver and he said yes it could happen because now i would be on the low end of the weight rating of the receiver. It's one thing hooking up your hitch while parked but it is another thing towing or back up with out the spring bars....Just something to think about!
Name:	Reese WD&S Control System.jpg
Old 11-30-2011, 08:07 AM   #29
alageezer's Avatar
The above picture brings up another point. If your trailer hitch is mounted on the bottom of the tongue, the square bars pictured are the preferred method. However, if your hitch is on top of the frame, a round bar system offers better clearances. The bars pictured in Post 14 above are what I'm talking about.
Edited to add: looked up a picture of a Flagstaff, and it has the hitch mounted on the bottom of the frame. So the bars pictured above would be fine. Equalizer uses the same type bar set uo.
Old 11-30-2011, 08:31 AM   #30
MtnGuy's Avatar
Originally Posted by alageezer View Post
T If your trailer hitch is mounted on the bottom of the tongue, the square bars pictured are the preferred method. However, if your hitch is on top of the frame, a round bar system offers better clearances.
Excellent point. I did not know this when I got my Reese setup. My coupler is mounted to the top of the tongue, plus I have a 6" tongue frame. That caused the square spring bars to rub the yoke bolt during sharp turns. I now use a 1" raised ball to prevent the yoke bolt rub, the spring bars will still rub the yoke during sharp turns.
chevy express 2500, cincinnati, flagstaff
