Forest River Forums
Sunline User Photos
Old 11-27-2011, 08:17 PM   #1
Must Reese dual cam be removed to back up? Is Equlizer simpler?
Just ordered a Flagstaff 831QBSS. Am trying to research hitches while awaiting camper delivery. Simplicity of hitch operation (quick, easy) is important to me. I would love to obtain good sway control, yet not have to get out of the tow vehicle and unhood or remove any hitch or sway parts before backing up. I'm currently undecided between Reese dual cam or Equilizer 4 point sway control.
I've been told that Reese dual cam may provide better sway control than Equilizer, but the Reese cams must be disconnected before backing up. Does anyone know for sure if Reese cams must be disconnected before backing up?
With a full size 3/4 ton Chevy Express van, I've towed a Flagstaff 827BH with round bars and chains, and friction sway bar for 10 years and had no problems backing up without unhooking the sway bar, but have been told I'm lucky the sway bar didn't bend.
Any voices of experience would be appreciated.
Ken-Judy is offline   Reply With Quote
Old 11-27-2011, 08:36 PM   #2
kalik282's Avatar
Ken-Judy, Welcome to the Forum!
Congratulations on ordering the new Flagstaff!
As for the Reese Dual-Cam, you don't need to take the bars off to back up. I usually do anyways, just because the hitch can be somewhat noisy at slow speeds. (The nature of the anti-sway function means no lubrication...) I figure, what's the difference if I take them off in the parking lot or the campsite. They have to come off sooner or later!
John & Nicole
2004 Ford Excursion 6.0L 4x4
2011 Flagstaff 831FKBSS
Nights Camped: '06=122 '07=12 '08=18 '09=10 '10=18 '11=28 '12=2
kalik282 is offline   Reply With Quote
Old 11-27-2011, 08:58 PM   #3
Moderator
I have a Reese dual cam, 3 years old, and over 3000 miles, and have been backing at near the turn limit, 70 degrees or so, and have never unhooked the bars to back up. Love the hitch, once it is set up right. Might take a test pull or two of few short miles.Make sure you get a copy of the directions for set up, and double check when the dealer gets through.
Windrider,
Too many toys, not enough time.
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
2000 Honda 750 Nighthawk
2008 Work and Play 18LT
windrider is offline   Reply With Quote
Old 11-27-2011, 11:01 PM   #4
Moderators' Assistant
bikendan's Avatar
IMHO, the Equalizer is simpler than the Dual-Cam.
that and not having to drill into the tongue, are why i bought the Equalizer.
Dan and Shawn and Zoe the Wonder Dog
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 11-28-2011, 07:56 AM   #5
Fire Instructor's Avatar
I've never taken mine off to back-up. It's a bit noisy backing (or taking sharp turns at low speed), but that's the friction that makes it work so well!
Be safe, and Everyone Goes Home!
Fire Instructor
2004 RAM 1500 4x4 Quad Cab w/Hemi, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 11-28-2011, 08:22 AM   #6
firephighter's Avatar
I have the friction anti-sway bar and was told by camping world(will always lower case this company) that it should be removed during backing. I was told it would bend in the backing process. I am going to continue this process for fear of having to replace the bar. Besides, I am not going to have much trailer sway in the campgrounds.I make a habit of once I pay for my stay, on the way to my trailer I remove the bar. That way I do not need to stop and do it at the spot I pick to stay in. Better safe than sorry in most cases.
firephighter is offline   Reply With Quote
Old 11-28-2011, 09:23 AM   #7
bikendan's Avatar
WDHs with the simple friction bar, do require you to unhook it to back up.
but higher end WDHs, like the Dual-Cam or Equalizer, do not require this. you just simply back in without any messing around with anything.
Old 11-28-2011, 09:27 AM   #8
Moderator
acadianbob's Avatar
X2!
A friction sway bar can be problematic but the Dual Cam does not have an issue if properly installed. IMO a benefit of the Dual Cam system is that it actively works to prevent sway in the first place; but rather than just damping sway action, it will try to push the trailer back into position.
http://i421.photobucket.com/albums/pp297/acadianbob/IMG_2757.jpg
2012 F150 FX4 Ecoboost, 2008 Surveyor 235RKS
2003 Yamaha FJR1300, Reese Dual Cam WD
1969 John Deere 1020, 1940 Ford 9N
Jonsered 535, Can of WD-40, Hostess Cupcakes
Old 11-28-2011, 10:44 AM   #9
great white's Avatar
While my hitch is not one of the ones you listed (Husky centerline, closest to the Equalizer) it is a WD sway hitch.
While mine can be backed and turned, I take the bars off before backing into a site.
Reason being, it's easier on the over all process.
If I get the trailer in and the truck isn't straight, getting the bars off is a b......
2011 Flagstaff Classic Superlight 831RLBSS "Atrium slide"
Husky Centerline Hitch
1998 GMC Sierra SLE K2500 6.5 Turbo Diesel
great white is offline   Reply With Quote
Old 11-28-2011, 01:40 PM   #10
Moderator
mtnguy's Avatar
Agree. Even after jacking the tongue up, there is still a lot of pressure on the outside bar. I always remove that bar 1st, allowing the inside bars to take some of the pressure.
Chap & DW Joy in Ruckersville, VA.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
mtnguy is offline   Reply With Quote
chevy express 2500, cincinnati oh, flagstaff 827bh, ken
» Online Users: 267
15 members and 252 guests
bikendan, bob34787, cardinal4fun, DAISY BOYKIN, darkcloud, deerslayer, digger47, lacroixyvon, Namchief, patmo2000, patrapper, pier pressure, rockwood06, SinkorSwim, walterw11
Most users ever online was 996, 05-22-2012 at 11:04 AM.
Close [X]
