Old 09-12-2012, 07:18 PM   #11
TURBS's Avatar
Originally Posted by locknload
I was under the impression that even if it was 220, it's only 110 per leg then the panel in the trailer divides it up as needed.
Aren't campgrounds wired 220?
Not to the outlet there not.
Only one leg of 110 goes into camper.
Other two prongs are neutral and ground
Old 09-12-2012, 07:25 PM   #12
locknload's Avatar
Originally Posted by wincrasher View Post
at a minimum, try plugging into a regular 15 amp 110 outlet using an adapter
That was the second thing I tried, no power still.
2010 Flagstaff 831RKSS.
2000 Excursion Limited PowerStroke Diesel- ATS ported housing, Riffraff's FRx, HPx & I/C boot kit, DiPricol Optix- Pyro/Boost/Trans, DP Tuner-80t, Drive-Thru, 80e, 120race, K&N intake tube w/6637, Exhaust, AIH delete, Foil delete, 4" lift, Airbags, Dunlop Rover M/TMaxx 315/75/16's, '04 headlights.
locknload is offline   Reply With Quote
Old 09-12-2012, 07:29 PM   #13
wmtire's Avatar
The only way a 110 volt camper uses one leg of a 220 outlet, is when you use a 50 amp to 30 amp adaptor plug/cord.
Campground pedestals can have a 50 amp (220 volt) plug in and an 30 amp (110 volt) plug in.
You can plug your 30 amp trailer into a 50 amp outlet, provided you have an adaptor, which the adaptor only uses one side of the 220, and makes it 110.
I have a bad feeling about this.
In the FAQ forum, Herk posted a pdf file on wiring a 30 amp 110 volt outlet for your home.
http://www.forestriverforums.com/for...let-27223.html
Also, you may want to read this: Make sure to check out the links to the left on 30 amp, 50 amp, and outlet testing.
http://www.myrv.us/electric/index.htm
2011 Flagstaff 831 RLBSS
I’ve lost my scapegoat.
Old 09-12-2012, 07:30 PM   #14
TURBS's Avatar
Don't feel bad man this happens more than you think !
At the minimum the converter/ distribution center is fried and not allowing power to the rest of the trailer .
Old 09-12-2012, 07:32 PM   #15
locknload's Avatar
OK well, guess I fried my trailer. Any idea what I'm looking at repair wise?
Old 09-12-2012, 07:34 PM   #16
locknload's Avatar
Thanks, I just missed your post when I posted. Is the converter/ D. center serviceable easily? Is it the panel with the breakers or is it buried deep within the bowels of the trailer?
Old 09-12-2012, 07:38 PM   #17
Herk7769's Avatar
My deepest condolences.
You will need to visit your dealer and call your insurance company.
Plugging a 30 amp camper into a 220 wired RV plug will be an expensive mistake. The panel in a 30 amp camper is a 110 VAC panel and will not "split it up."
Potentially damaged items:
Converter - For sure
Air Conditioner - Maybe
Microwave - Maybe
TV - Highly likely
Fridge - Maybe
Water Heater (if it was on) - For Sure
Hopefully your electrician buddy will help you with your deductible.
HAM CALLSIGN - KC3FFW
Old 09-12-2012, 07:39 PM   #18
Herk7769's Avatar
One of our other members said 2 grand.
(SOLVED) electrician hooked TT up to 220
Power converter issue
http://www.forestriverforums.com/for...-tt-13525.html
Fried my microwave
If you plug into 220 and not 110 what would happen
http://www.forestriverforums.com/for...elp-17056.html
Old 09-12-2012, 07:43 PM   #19
TURBS's Avatar
Converter is also the fuse breaker panel .
Easily accessible.
That whole unit pulls out after removing screws.
Old 09-12-2012, 07:47 PM   #20
wmtire's Avatar
Marcusfan was lucky last month, and got hers repaired for about $400, which included a rv service tech coming to her house and replacing the converter.
