Old 09-12-2012, 08:13 PM   #21
Old car's Avatar
I feel your pain. See a thread I started on 7/8 titled "Power Converter Issue". I lost my power converter unit, television, entertainment unit (radio, CD, DVD, etc.) and microwave. Saved the air, furnace, hot water heater, and fridge. Estimate--$2100+. Marcusfan was very lucky in how hers turned out. Luckily insurance covered mine less deductible. Good luck and let us know how it turns out.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 09-12-2012, 09:35 PM   #22
Phat Phrog Stunt Crew
awwall's Avatar
A good power monitor/surge protector would be a much cheaper investment. Learned the hard way from a power surge at home while coach was hooked up. (without protection) Never thought this would happen at home. Cost me 2 TV's in coach. I was lucky that was all it cost.
You can bet your sweet bipi that there is a Progressive Industries power monitor hooked up anytime coach is plugged in.
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 09-13-2012, 06:02 AM   #23
Earth Station's Avatar
I was so worried when we had a 50 AMP put in at home. He was an electrician but I have read all the horror stories. We did purchase a surge protector and it is ALWAYS at the end of the power cord! No matter where we are plugged in.
Felicia & Jeff - Missouri
2013 Columbus - 320 RS 2012 F350 CC DRW - 6.7L PSD
2012 Camping 59 DAYS; 2013 50 DAYS; 2014 WAITING
Earth Station is offline   Reply With Quote
Old 09-13-2012, 06:49 AM   #24
TURBS's Avatar
Locknload
If your going to take your camper to the dealer for insurance purposes and your converter / distribution center is a wfco brand up grade it to a progressive dynamics inteli power converter.
Even if your going to do it yourself pay the little extra for a PD power center.
As I stated start there.
I switched my unit in short order it's not that hard .
And get your electrician back to fix your outlet.
Please keep us updated.
Turbs
Old 09-13-2012, 07:33 AM   #25
wmtire's Avatar
Originally Posted by f1100turbo View Post
Locknload
Turbs
X2
And it might help to print out the 'wiring a 30 amp outlet' pdf file to give to your electrician.
As you have read, it happens several times, so don't fret it.
As Awwall and EarthStation pointed out, adding a surge protector would have prevented this also.
2011 Flagstaff 831 RLBSS
I’ve lost my scapegoat.
Old 09-13-2012, 07:36 AM   #26
TURBS's Avatar
Originally Posted by wmtire
X2
I bet the electrician only makes that mistake once !!!!!
Old 09-13-2012, 09:02 AM   #27
AquaMan's Avatar
I would check with the electrician to see if he is bonded and insured. If he installed the proper recepticle for an RV, he should know that it is 120V only. The plug looks similar to a NEMA 10-30, which is 120/240, but an RV TT-30 is a 120V only recepticle. At least all my plugs and recepticles had always stated that.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 09-13-2012, 09:29 AM   #28
TURBS's Avatar
I believe my (two) 30 amp plugs at my house say right on them .
(For rv use only 110 v.a.c.)
Old 09-13-2012, 02:26 PM   #29
locknload's Avatar
The electrician is my friend/neighbor and I take full responsibility for this mess. I told him it was 220V.
**Update**
In the house panel on the 220V 30A breaker for the new outlet, I moved the neutral wire to the neutral bank and tested voltage at the outlet to be sure I was getting the correct voltage. I had 122.5 on one leg only. So I plugged in the trailer to the new outlet and turned on the main breaker in the trailer panel. Turned the indoor fridge on and the main light came on. The AC works and the outdoor fridge and microwave work as well. I heard the water heater hissing too, I need to hook up water to check for sure but the propane is off so it looks good. (An hour or so later I checked on the fridge and it's getting colder inside).
So far I have zero power to the living room TV and indoor microwave. If that's all I lost, I feel incredibly lucky and feel fairly confident I will win the next Powerball. I still need to pull the indoor microwave to see if there is a GFI behind it or even check and see if the bathroom GFI is popped.
2010 Flagstaff 831RKSS.
2000 Excursion Limited PowerStroke Diesel- ATS ported housing, Riffraff's FRx, HPx & I/C boot kit, DiPricol Optix- Pyro/Boost/Trans, DP Tuner-80t, Drive-Thru, 80e, 120race, K&N intake tube w/6637, Exhaust, AIH delete, Foil delete, 4" lift, Airbags, Dunlop Rover M/TMaxx 315/75/16's, '04 headlights.
locknload is offline   Reply With Quote
Old 09-13-2012, 02:33 PM   #30
TURBS's Avatar
You need to check you converter output .
You may just be running on battery power as for as the lights go.
There's a trouble shooting guide in the files section upper left hand corner of web page.
I hope it only gets better for ya !
But man so far not to bad !
Turbs
