Old 09-12-2012, 06:54 PM   #1
locknload's Avatar
Need help, camping Friday
We have a 2010 831RKSS. I went to plug in the trailer tonight and found no power, completely dead. Checked the fuse panel inside and it is dead as well. No red lights on the right and a couple breakers on the left were tripped. I reset those breakers and I could hear the water heater kick on then its breaker tripped again.
Is there another breaker or fuse panel somewhere else that I'm missing? The trailer worked fine when we parked it last month. I did have an electrician add an outside 30 amp outlet to the side of the house and we tested the trailer after install and everything worked as it should, even the AC.
Any help would be great as we're suppose to leave Friday afternoon and have the weekend already paid for. Thanks.
2010 Flagstaff 831RKSS.
2000 Excursion Limited PowerStroke Diesel- ATS ported housing, Riffraff's FRx, HPx & I/C boot kit, DiPricol Optix- Pyro/Boost/Trans, DP Tuner-80t, Drive-Thru, 80e, 120race, K&N intake tube w/6637, Exhaust, AIH delete, Foil delete, 4" lift, Airbags, Dunlop Rover M/TMaxx 315/75/16's, '04 headlights.
locknload is offline   Reply With Quote
Old 09-12-2012, 06:57 PM   #2
TURBS's Avatar
uh oh ...............
did he hook the outlet as 220 volts ?
Old 09-12-2012, 06:58 PM   #3
locknload's Avatar
Yes, on a 30A breaker.
Old 09-12-2012, 07:00 PM   #4
TURBS's Avatar
Camper is only 110 .
You may have fried all your electronics
Or should I say he dId.......
Old 09-12-2012, 07:02 PM   #5
TURBS's Avatar
Microwave
Converter
A/c
Fridge
Tv's
Hw heater
There 110 v
Electrician's whom are not campers don't realize this because of the style of plug that's used .
It resembles a dryer plug which is 220v
Old 09-12-2012, 07:05 PM   #6
if that was the case, he would have fried on the initial plug in.
i found my sunset trail similarly dead last weekend. the plug had slipped out partially from the 110 15 amp outlet i had it connected to. i reseated the plug and it must have reset the coverter, because everything returned to life.
crasher is offline   Reply With Quote
Old 09-12-2012, 07:06 PM   #7
DDC
DDC's Avatar
If he did the air should have blown immediately but the fact that breakers were tripped sure makes you wonder, check the voltage at your new outlet first.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 09-12-2012, 07:08 PM   #8
TURBS's Avatar
Not true at all ! A month or so same thing happened to another poster .
They turned air on and seen it worked .
They shut everything off and days later went back and nothing worked.
Old 09-12-2012, 07:09 PM   #9
at a minimum, try plugging into a regular 15 amp 110 outlet using an adapter
Old 09-12-2012, 07:11 PM   #10
locknload's Avatar
I was under the impression that even if it was 220, it's only 110 per leg then the panel in the trailer divides it up as needed.
Aren't campgrounds wired 220?
