Old 06-18-2013, 07:37 PM   #1
medja's Avatar
Need help with scare light replacement
Scare light on my V Lite is rusting on the outside rings. Purchased a new one that hopefully will last longer than the one I have now. If I turn off the power to the trailer do I still need to be concerned about the power from the battery? If yes how would I turn that off? I'm not used to doing this kind of work so, yes you're right......I'm dumb about this but determined to do it myself. Any help will be greatly appreciated.
medja is offline   Reply With Quote
Old 06-18-2013, 08:07 PM   #2
Send a message via MSN to Tiggerdad
If the switch to turn off and on is off, you should be good to go. Watch the cover for a hole. Must point down or it will catch water and leak into where the wires are.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 06-18-2013, 09:32 PM   #3
medja's Avatar
Scare light
Thanks for the response. My husband always did these things but now than he is gone I have to figure it out. Thanks again!
Old 06-19-2013, 07:47 AM   #4
Remember that all members are here to help at any time and with any problem
Old 06-25-2013, 09:55 AM   #5
Hmmmm...My V lite has plastic scare lights, if you are describing the light at the doors. I put one in at the bedroom door, as well. Made both lenses yellow. Randy
Old 06-25-2013, 10:06 AM   #6
You might want to consider using the Starlight security replacement. Amazon.com: StarLight SL-2000 Smart Light Round Light: Automotive
Old 07-21-2013, 07:13 AM   #7
I'm not an electrician but I would think you would be OK if you have the light turned off at the switch that controls the scare light you are working on. You could always get one of those little circuit testers to be sure the wires are dead.
tsuther is offline   Reply With Quote
