Old 01-02-2019, 07:33 PM   #1
Need Urgent Help Please (hot water)
We just purchased our Flagstaff 5th wheel and canít figure out how to get hot water. Weíre thinking there may be a hot water shut off valve that was turned off when the trailer was winterized. Please help!!!
cborn777 is offline   Reply With Quote
Old 01-02-2019, 07:40 PM   #2
Who Dares, Wins
doc73's Avatar
If you look behind your water heater there may be 2 or 3 valves. They are used to seal off the tank from when you winterize. If the tank is full of water and the HW heater is on this might be your issue.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 01-02-2019, 07:44 PM   #3
Hot water bypass valves are usually behind the water heater. Look for an access panel near where you see the outside acess to the water heater. There are several set ups, including 1 (maybe), 2 and 3 valves, but once you find it:
1. Be sure water flows into the water heater
2. Water flows out of the water heater
3. No water bypasses the water heater
Hope that helps.
Skip12 is offline   Reply With Quote
Old 01-02-2019, 08:36 PM   #4
Flybob's Avatar
You are looking for something like this. Note if you turned on the electric portion of you WH without water in it, you likely burned out the heating element as it only takes seconds.
You will want to change the position of each valve. Not the handle of the valve usually points in the direction of the water flow. Perpendicular to the PEX is off while Parallel to the PEX is on.
Name:	WH Bypass 2 valve.jpg
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-02-2019, 08:42 PM   #5
007matman's Avatar
Make sure the system is off and cooled down prior to opening those valves (if it's been closed and the water heater in the "on" position).
You don't want to dump a bunch of cold water into a hot water heater.
007matman is offline   Reply With Quote
Old 01-02-2019, 08:49 PM   #6
bikendan's Avatar
cborn, it would help if you posted year and model of Flagstaff you have.
That way owners of the same model, can be more helpful.
Equalizer WDH
Old 01-02-2019, 08:51 PM   #7
You also donít want to go turn on an empty hot water heater.
spydunks is offline   Reply With Quote
Old 01-02-2019, 11:06 PM   #8
wmtire's Avatar
Originally Posted by cborn777 View Post
We just purchased our Flagstaff 5th wheel and can’t figure out how to get hot water. We’re thinking there may be a hot water shut off valve that was turned off when the trailer was winterized. Please help!!!
This thread that we keep as a sticky at the top of the plumbing section may help:
NO (OR LUKEWARM) HOT WATER -Please read first
Also if you have tank type Suburban water heater, this thread may help too:
Suburban's electric switch and much more
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 01-03-2019, 07:12 AM   #9
Itís a 2018 Flagstaff 526RLWS.
Old 01-03-2019, 07:21 AM   #10
I had the same issue when first purchased my Rockwood. Finally found the bypass and had water in the heater. However it burned up the the electric element but the dealer sent a tech to my house and repaired. The bypass should have been open when the sold.
Rdeejr is offline   Reply With Quote
