Old 07-22-2019, 01:36 PM   #1
NEW 25 FKS owner - Black Tank Flush?
Hello all... first post, and my first travel trailer!
Im actually loving it as we learn along the way. Recently just returned from Yosemite National Park and have a question about FLUSHING the Black Tank: HOW DO YOU DO IT?
Is there a connection for a Black Tank Flush on the 25 FKS, if not whats the best way to flush the tank
thanks in advance!
WA_25FKS is offline   Reply With Quote
Old 07-22-2019, 01:51 PM   #2
Do a search on the topic. Lots of people manage this in different ways.
If you have a BT flush it should be labeled on your rig.
gbaldwin is offline   Reply With Quote
Old 07-22-2019, 01:57 PM   #3
thanks, thats why I decided to ask. I did NOT see one on the Trailer. Just the Antifreeze Inlet. I scoured youtube looking for anything and various trailers had the black tank flush but Im wondering if it was an "option" I needed to added to add when the trailer was built.
Old 07-22-2019, 01:58 PM   #4
Welcome... 1st post.
There are many posts on black tank flushing and maintenance
The first stop will be the Library section.
Here is a link... FRF LIBRARY
Next would be a search. here is one such search link...
Black Tank Flushing
Did you buy this unit new?
This (and many other R/V 101 items) should have been part of your PDI/Customer Orientation.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 07-22-2019, 02:04 PM   #5
It will look just like a city water connection but labeled Black Tank Flush.
If you dont have one, a hose down the toilet accomplishes about the same.
Type in search box above...Black tank flush cleaning
Old 07-22-2019, 02:13 PM   #6
Black Tank Flushing
yes, brand new this March, it was not discussed in the orientation.
Old 07-22-2019, 04:37 PM   #7
Riverbc's Avatar
On my Rpod it looks like this
https://i.imgur.com/t6krhfM.jpg
Riverbc is offline   Reply With Quote
Old 07-22-2019, 04:58 PM   #8
Attachment 210546
thanks for the pic. Ive looked for a black tank flush port and we just don't have one on the trailer. I did receive some great info and product recommendations that should alleviate the problems
Old 07-22-2019, 05:07 PM   #9
MT Biker's Avatar
From pictures of new 25fks it looks like the black tank flush is on the back of the trailer, either next to your fresh water inlet or on opposite side where if you have a ladder factory mounted it is behind the ladder. Every picture I try looking at is blurry, but you should have Fresh water inlet, city water inlet, anti freeze inlet and black tank flush all on the rear of the trailer.
https://www.facebook.com/westshorerailway/
2019 Ford F-250 Super Cab 6.2L Lariat
2016 ML23FB
MT Biker is offline   Reply With Quote
Old 07-23-2019, 11:21 AM   #10
thanks MT Biker, I'll take a look. Its hard to look up as they are all slightly different. I'll let you know what I find out
Old 07-23-2019, 11:33 AM   #11
https://www.amazon.com/dp/B0006IX7YC...v_ov_lig_dp_it
My brother-in-law swears by this dohicky.
Mrs.Shockley is offline   Reply With Quote
Old 07-23-2019, 02:48 PM   #12
I have a 2017 25 FKS. The black tank flush fitting is on the drivers side ( same side as the slide) just above where the power cord hooks up.
It is in a great spot. Very convenient when dumping the tanks. I dump the black tank first, then hook a water hose to the black tank flush fitting and let it run for 15 minutes if time and traffic allows. Then I dump the two gray water tanks last.
This process works great for me. No odor in the trailer ever from the black tank.
morganrc1955 is offline   Reply With Quote
Old 07-23-2019, 03:16 PM   #13
Chris and Cecil
black tank flush inlet
thanks in advance!
On our 25FKS it's on the driver side of the trailer, above the power inlet. It doesn't say black tank flush but has a sign under it that says Caution Do not use the tank flush valves unless the fullway termination valve is in the open position. I'll send a picture.
Dentist said I needed a crown.
I was, like, I know!
2018 Flagstaff Microlite 25FKS
2017 Dodge Ram 1500 EcoDiesel
Alabama Potter is offline   Reply With Quote
Old 07-23-2019, 03:20 PM   #14
Chris and Cecil
Here's a picture turned sideways - sorry
Name:	black tank flush inlet.jpg
Old 07-23-2019, 03:43 PM   #15
MT Biker's Avatar
I was looking at pics of a 2020 model. If you just received yours I assume this is what you have.
2016 ML23FB
Old 07-23-2019, 09:51 PM   #16
Greetings. Look on the passenger side of the trailer for the black tank flush. We have a 2020 Rockwood 2608BS and it is on the passenger side of our trailer under the television mount.
Momma Tac is offline   Reply With Quote
Old 09-19-2019, 05:29 PM   #17
What is Fullway Termination Valve?
I have the same label near my black tank flush, and I have no idea what a "fullway termination valve" is, or where it might be located on my 2304DS.
Can anyone help?
Paul Dershem is offline   Reply With Quote
Old 09-19-2019, 05:49 PM   #18
Blackrock's Avatar
Can anyone help?
Ah yes the dreaded Fullway Termination Valve
That is what the slide gate valve is called that you open to dump the tank.
Now lets all chip in and warn about what happens if you run the black tank rinse with the fullway termination valve closed.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 09-19-2019, 05:52 PM   #19
Can anyone help?
It is nothing more than the black/grey/galley dump valve(s).
The 'industry' calls them fullway termination valves.
R/Vers call them dump valves.
Old 09-20-2019, 10:51 AM   #20
This video shows you exactly where it is. Jump to the 4:15 minute mark to cut to the case. I've also attached a picture. Oddly it is not labeled clearly as the BTF connection on the unit showcased here which I'm sure confuses a lot of people. Video.
JoeCampsNE is offline   Reply With Quote
black, black tank, black tank flush, flush, tank
