Old 11-12-2013, 08:29 AM   #1
New Flagstaff owner questions (Entertainment related)
831BHDS 2014
I haven't taken ownership yet (spring 2014) but she's all paid, lol
So I have a couple of questions.
1. The Cable Satellite input [outside hookup] is there a separate one for cable/sat?
a. If it's separate how does it get to each TV (bedroom/living room/bunk?)
b. If there is only 1 input outside, how can you get different channels per TV?
2. Genesis 3.0 I have been reading horror stories about the wiring (lack of??) on Forest Rivers part (cable configurations not connected) for TV audio to get to the entertainment center / Genesis 3.0
3. I have also been reading about bad Genesis’s? Thoughts on this unit?
2014 Flagstaff 831BHDS
2010 Ram 2500 Cummins 4.10s - Superchip'd
Built-in Controller
Hellwig Sway Bar 7272
Equalizer Hitch system
Long Islander is offline   Reply With Quote
Old 11-13-2013, 08:00 AM   #2
Herk7769's Avatar
I don't own your camper, but I have the Genesis 3.0
1) The single SAT input only goes to the main switcher wall plate (labeled AUX/SAT) in "most" installations, (maybe not yours depending on who made your roof antenna). See photo for the Winegard wall plate to look for.
See the attached PDF for one way to connect the SAT input to the camper's coax distribution center.
2) I do not own a SAT system (yet), but the system needs to be able to "ride" multiple dish signals (more than one LNB) on a single coax. See PDF.
Here is an article that might help. HOOKING UP MULTIPLE SATELLITE RECEIVERS
3) I LOVE my Genesis 3. However, since the dealership actually hooks up the television and not the factory (the TVs are shipped in the original shipping box), they are seldom hooked up correctly.
a) The correct output to the TV should be an HDMI cable but they cost a LOT more than the cheap 3 wire composite/stereo (Yellow, Red, White RCA plugs) one most dealerships use.
You will need to trash that and buy an HDMI cable long enough to get from the main TV HDMI input to the Gen 3 output on the back for high-definition output from the DVD player in the Gen 3.
b) Getting audio FROM the TV to the back (or front) of the Gen 3 (or any other make of sound system depends on the brand of TV shipped with your unit.
If it has stereo RCA (Red and White) audio out, you can use those outputs to run to any RCA audio input on the Gen 3.
If your TV has a digital output (required to get true surround sound from the TV to the Gen 3), you will need to buy a digital (fiber optic) cable long enough to get from the TV to the back of the Gen 3 (where the digital input is located).
Name:	Gen 3 inputs.jpg
ID:	42556   Click image for larger version
Name:	ZX-800 connections.jpg
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 11-13-2013, 08:05 AM   #3
Herk7769's Avatar
OH! and use CARE when removing the faceplate to get at the mounting screws. The faceplate can be broken if you don't know how to remove it.
There are two "slots" underneath the faceplate. Insert a wide blade screw driver and carefully twist it to pop the lower corners away from the body.
LIFT from the bottom to remove the faceplate to access the screws.
If you try to force the faceplate off (or pry from the top) you will break the tabs that hold the top portion on the unit.
Old 11-13-2013, 08:26 AM   #4
Long Islander. Above explanations are the best you can get. I don't think that your dealer knows half of it. If at all. :-)
Flying dutchman is offline   Reply With Quote
Old 11-13-2013, 10:38 AM   #5
herk7769,
Thank you for the reply. I have the Toshiba (Main TV) so I dunno at time what outputs there are. But I clearly understand what you wrote. I will obviously re-wire it properly now!
(No issues wiring, did it for home TV)
I will report back with pictures in this thread for future readers
Built-in Controller
Old 11-13-2013, 02:22 PM   #6
My guess from looking at the "features" sheet is that there is only one connector used for both Cable and Sat. Hopefully an owner can answer that question.
For off-the-air & Cable service, the signal is distributed with splitters included in and perhaps connected to the back of the Antenna Booster Control plate. Here's a diagram:
You get different channels on different TVs because the full spectrum of channels is present on the cable and passed to each TV.
Now if you're talking about Satellite (can't really tell from your post), the story gets a lot more complex. In that case, depending on the hardware you have/buy, it may not be possible to get different channels on different TVs.
If that is you interest, please start by telling me if you have Sat service at home and if so, with which Sat provider? Secondly, do you want to use an automated system (like the Dish Tailgater or a Winegard Carryout), or are you willing to setup and aim your own dish (easy enough to learn to do)?
Old 11-13-2013, 03:39 PM   #7
Phat Phrogs Incognito...
DutchF's Avatar
Guys, regarding the cost of HDMI cables (or others for that fact) I would *HIGHLY* recommend you get them from monoprice.com
Friends, coworkers, family and I have been buying from them for years. Always excellent quality, never a bad product and prices... Well, I just ordered 4 more HDMI cables for our RV and the were $2 - $3 each.
Just tying to help.
One more thing, I just installed DirecTV in our RV and we get HD, local channels and can watch different shows (while even more are recording) in the living room, bedroom or outside (basement). Aiming my dish takes about 5-10 minutes. No additional monthly charges (we have DirecTV at home). I've posted a couple threads about it, recently. They may or may not help, but I hope they do, or at least stir up some brain cells and good conversation.
Cheers!
Tina + Dutch and Bell, Bobo, Harley, Buddy (the dogs)
2011 F350 Lariat 4x4 DRW SuperCrew 6.7L (B&W setup w/Air Lift 5000 Ultimate)
2014 Columbus 365RL (Airflex and Voyager package)
Nights Camped 2014 - 154, 2015 - 32, 2016 - 4
DutchF is offline   Reply With Quote
Old 11-13-2013, 04:09 PM   #8
Herk7769's Avatar
I get my cables online as well.
I use : MyCableMart.com
If the dealer puts it in they will charge you for Monster HDMI cables, most likely.
Amazon.com: Monster Cable MC ISF750 HD-5 EFS 5-Feet HDMI Cable: Electronics
Old 11-13-2013, 04:12 PM   #9
I have extra HDMIs and optical cables here
Built-in Controller
Old 11-13-2013, 04:13 PM   #10
Originally Posted by DutchF View Post
One more thing, I just installed DirecTV in our RV and we get HD, local channels and can watch different shows (while even more are recording) in the living room, bedroom or outside (basement). Aiming my dish takes about 5-10 minutes. No additional monthly charges (we have DirecTV at home). I've posted a couple threads about it, recently. They may or may not help, but I hope they do, or at least stir up some brain cells and good conversation.Cheers!
This is why I figure I setup Direct TV in my TT. I already have Direct TV at home so it's 'free'
I'll look up your posts to do some reading.
Built-in Controller
Old 11-13-2013, 04:20 PM   #11
DutchF's Avatar
Herk, not trying to start anything, looks like cablemart sells the same stuff as monoprice, but this (commonly used) example is about half the cost. I would recommend checking both. I will, on the chance cablemart has a better deal or something that monoprice doesn't carry. Thanks for the link!
I found out about monoprice from the AVS forums (tons of audio/vide phile types)
$4.33 - 1.5ft High Speed HDMI Cable with Ethernet 10.2Gbps 28AWG Gold Plated
MyCableMart.com
$2.14 - 1.5ft 28AWG High Speed HDMI® Cable With Ethernet
1.5ft 28AWG High Speed HDMI&reg Cable With Ethernet w/ Ferrite Cores - Black - Monoprice.com
Old 11-13-2013, 04:25 PM   #12
Herk7769's Avatar
Not to put too fine a point on it, but under 5 bucks is better than 60...
Old 11-13-2013, 04:30 PM   #13
DutchF's Avatar
You could not be more correct, Herk!
Reminds me of one of my SiL's, who was convinced his $100+ Monster stereo cables were the best and made his music sound better.
Let's just say that he eventually understood the difference between marketing and real world performance.
flagstaff
