Old 08-19-2010, 11:32 AM   #1
locknload's Avatar
New here, possible Flagstaff 831RKSS
Hi guys, just found this board. My wife, kids and I have been looking seriously at trailers. I've towed vehicles before but never a TT, this will be our first. I know we have lots to learn.
We started out looking in the $10K range but wanted a slide out and newer model, well... that got us looking even higher. We looked at a 2010 Flagstaff 831rkss. We love it, the outdoor kitchen almost seals the deal alone. It's set up the way we wanted, three rear bunks should suit our 4 and 6 year old tyrants fine. Plus lots of room for friends.
So my question is for around $25K how's this trailer, model and brand? It seems to have good construction and the fixtures and peripherals seem to be upgraded as well. Our worries in buying a less expensive trailer is we may want to upgrade sooner than later and don't want to lose money that fast. I think this is a unit we could grow into rather than out of.
My only other concern is the length, it says 33ft but also says 31ft, I'm guessing 33ft tounge to tail. We started looking at 26 footers but couldn't find the floor plan we liked so the 30 footers came into view. Is a 33footer that much harder to move around than a 26 footer? I know the longer the trailer the easier it is to back up but still...
Our tow rig is an 7.3 Excursion with airbags so we should be fine there. Thanks for all your help. Like I said, we have alot to learn and will be here absorbing all we can.
locknload is offline   Reply With Quote
Old 08-19-2010, 11:38 AM   #2
Watch your wheel base, I can't remember what it is on an Excursion, around 140 inches. You will also need a good anti-sway hitch.
A quick rule of thumb is to multiply the overall trailer length by 5, and that is what the minimum wheel base (in inches) of the truck should be. Also, you can go by this chart:
110" 20' ******* 150" 30'
114" 21' ******* 154" 31'
118" 22' ******* 158" 32'
122" 23' ******* 162" 33'
126" 24' ******* 166" 34'
130" 25' ******* 170" 35'
134" 26' ******* 174" 36'
138" 27' ******* 178" 37'
142" 28' ******* 182" 38'
146" 29' ******* 186" 39'
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 08-19-2010, 11:49 AM   #3
locknload's Avatar
Checked some sites online and my wheelbase should be 137", I can measure when I get home. 33'x5=165" so I should be good, thanks. I think the Excusrion chassis is the same as an F250 extra cab short bed.
Old 08-19-2010, 01:27 PM   #4
Better check your math. 33 x 5 does equal 165, and the chart says that is the MINIMUM wheelbase, so that means you need at least 165 inch wheel base. If the Excursion is indeed 137, then you are few inches short for that length trailer. I'm not saying it won't do it, but you may get some sway issues, especially if the excursion has auto leveling and ride control.
LadyWindrider
Old 08-19-2010, 01:38 PM   #5
Grape Escape
Lets get real .What bigger tv can you get? Excursion is more than adequate to pull a 33' trailer.
Get the bigger trailer as it will only be a matter of a short time you will be wanting to upgrade.
Speaking from experience 3 trailers in 4 yrs and we have exactly what we want now.
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 08-19-2010, 02:40 PM   #6
MtnGuy's Avatar
Windrider is correct that the suggested minimum wheelbase for a 33 foot travel trailer should be 165". That chart and calculation that Windrider posted is a popular "suggested" travel trailer length to tow vehicle wheelbase ratio that is widely used on RV forums. Flagstaff lists that trailer as being 34' overall......1 of the longest bumper pull trailer that is offered by Flagstaff.
The longer wheel-based a tow vehicle is, the better. By the chart and calculation, you would need a full sized, crew cab, long bed pickup to tow a 34 footer. But.........and I don't say this lightly..........an Excursion is a beast of a tow vehicle, and may be able to safely tow a little longer trailer than the chart suggests, but we have no way of knowing how long. There should be some chart allowing for the wheel base ratio on heavier built vehicles, but there is none that I am aware of. Even though that is a heavy duty SUV, that long of a trailer is going to try to push your Excursion around on the road, especially during hard braking.
If the Excursion had an extra 3' of wheelbase, it would be the ideal tow vehicle for that camper. For me, even though it is a 3/4 ton SUV, the 137" wheelbase would be a concern, and I don't think I would do it.......that is JMHO.
Also, plug in the stats of your Excursion into the Ford Towing Guide (https://www.fleet.ford.com/showroom/...ng/default.asp) to make sure you are good to go as far as tow capacity. Some engine and final drive ratio combinations are rated as low as 6100 lbs. maximum towing capacity.
Old 08-19-2010, 03:12 PM   #7
locknload's Avatar
Oops, my numbers were off, long day at work. My Excursion is rated for 11K lbs. The hitch is rated at 5K or 10K. I see what you're saying about a longer wheelbase but it's sure hard to believe this monster would have a problem.
2010 Flagstaff 831RKSS.
2000 Excursion Limited PowerStroke Diesel- ATS ported housing, Riffraff's FRx, HPx & I/C boot kit, DiPricol Optix- Pyro/Boost/Trans, DP Tuner-80t, Drive-Thru, 80e, 120race, K&N intake tube w/6637, Exhaust, AIH delete, Foil delete, 4" lift, Airbags, Dunlop Rover M/TMaxx 315/75/16's, '04 headlights.
Old 08-19-2010, 03:55 PM   #8
Grape Escape
According to the weight police you will need either a stretch limo or a crew cab long box. Hog wash.
May as well get a 5th wheel if you go that route and a Kenworth to pull it.
I personnally towed a 29 foot tt with short wheelbase Tahoe and never once felt unsafe. Our friends pull a 28'tt with an Olds Bavada(Trailbazer) all over the country.
Perhaps if these people stayed close to the speed limit and never over 60 mph they would not have these concerns.
Old 08-19-2010, 04:15 PM   #9
The Old Man
Willis's Avatar
+1
2010 Flagstaff 829RGSS
Still to go: AK, NL, NT, NU, YT
Willis is offline   Reply With Quote
Old 08-19-2010, 07:27 PM   #10
Welcome to the forum, locknload. If you buy nearly anything from Forest River there is probably someone here you can brag to or get help from if you need it.
Our trailer has the same exterior dimensions as the one you arre looking at, just over 34 feet if you don't count the spare tire hanging off the back. Ours is front kitchen.
We like ours. We bought it with free standing table and chairs which really opens up the interior. We ordered it from a trailer show demo so it's pretty loaded up.
Brickbats -- nothing real substantial. I've got a short in the front powered stabilizer, either I'll find it and fix it or the dealer will. The water heater by-pass valves are accessed through a cabinet under the kitchen sink, but, they boxed it in at the factory and I had to remove that to get at the valves. I can fix that too. One of the dust caps came off the axle by itself and I had to tap it back on. Stayed on ever since.
One thing you will notice with these large, but still 'lightweight' trailers is that they have a lot of flex in them. You will need wheel locks to help keep it stable when you are set up to camp. The front and rear stabilizers alone will not do it. We have to be very careful about leveling our trailer before we run the slides out. If we don't, the bathroom door won't latch shut.
Towing -- You should easily be able to tow the trailer you are looking at with an Excursion equipped with PS diesel. The last time we weighed our rig (mid July), the trailer had 7,150 pounds on the axles and the truck had 6870. That's hitched up with 43 American gallons of water in the various holding tanks. We've pulled it around 1,500 miles this summer, not in the mountains, but, we have pulled some fairly serious hills in Alberta foothills country.
The wheelbase chart that has been mentioned has been around for a long time. I'm going to suggest that the engineering improvements to suspension systems both of trailers and on trucks have rendered it a bit obsolete. Our truck has 143 inch wheelbase and we've had no troubles to date (touch wood), and I did spring for a Reese dual cam hitch. Similar weights between towing and towed vehicles may also help. I try to cruise at around 60 mph.
2011 Flagstaff 831FKBSS
2007 GMC Sierra 1500 Ext Cab, Vortec Max
Prodigy, Reece DC
GAL119 is offline   Reply With Quote
Old 08-19-2010, 07:57 PM   #11
Grape Escape
Welcome locknload.
Sorry for the ranting but I just can't stand these weight police scaring off people by stating you need a monster truck to tow anything beyond a utility trailer. A must is a weight distr'g hitch with sway control such as Reese dual cam or Equalizer brand with the sway bars and it must be setup correctly and you will have no problem towing.
I cannot believe how many I see passing me going 70-80 mph towing a large trailer. Utter nonsense with no regard to anyone's safety.
Buy what you really want from the start and with your tv you will have no problems
PS not much price difference going from 26 to 32 ' trailer so you will appreciate the added space for small price difference.
Old 08-19-2010, 10:18 PM   #12
I personally don't care if you tow it with a motorcycle, it's stopping it that concerns me. All that is between you and trailer brakes working properly is a 30 amp fuse. One naked wire near an axle, and that is history, and now you have NO trailer brakes. Without some help from a proper wheel base vehicle, it doesn't take much to jackknife in this situation.
When is the last time you were under your trailer and inspected the brake wiring? It's one thing to be able to do it, and after reading all the post, I think everyone agrees the Excursion with the diesel will pull it. The weight is even under the tow limits, but there could be potential problem with sway based on wheel base. Also the Excursion probably has softer sidewall passenger tires, and since I am a mechanic, I am concerned with the airbag setup on the vehicle. I'm not sure it is strictly for load leveling, or it tries to adjust each air bag individually when cornering, or on rough roads. After all, Ford has a better idea, they just don't always publish all the facts along with it, (for instance, do not a an Excursion on a lift without first disabling the airbag system). True of most vehicles with airbags.
Now for my last rant, and then I'll get down. I want us all, (everyone on the forum and elsewhere), to remain safe, and not have a wreck that blocks the road and MY vacation time!
Maybe because of my airplane pilot training, I like to be prepared for emergencies, so they aren't emergencies, just a change in the routine. No trailer brakes is number one. Had it happen one time on a 14% decline, and yes, I made it fine. Many of today's vehicles have the power to tow, but not the frame or suspension. Anti sway hitches have come a long way, and give many a false sense of security. Just remember, when the wind is from the right, and the tractor trailer passes on the left, the wind will reverse, and sway will be induced, how you get out of it, or get it under control, will depend on when you last replaced your wiper blades.
LadyWindrider
Old 08-19-2010, 10:56 PM   #13
Also need to check this thread, looks like an Excursion to me!
Tail Wagging The Dog
LadyWindrider
Old 08-19-2010, 11:56 PM   #14
That's why I pull a fifth wheel.
Yikes!
Old 08-20-2010, 07:04 AM   #15
Grape Escape
"Windrider" How many pictures would you like to see with 18 wheelers flipped, jacknifed etc?
All these what ifs?
What if your front tire falls off the tow vehicle?
What if whole electrical system fails?
What if driver falls asleep?
What if someone crosses centre line?
What if you have the dreaded runaway accelerator pedal?
While descending steep grades my truck transmission and engine do all the braking automatically. It has been designed that way.
Have yet to see any manufacturure's towing literature limiting trailer length due to wheelbase size anywhere. (Sure they would with all the legal jargon on every other item in owners manual)
Old 08-20-2010, 07:45 AM   #16
locknload's Avatar
My airbags are not a comfort factory option, they're Airlift 5,000lb load bags. My tires are E rated plus they're a tad wider than factory being 315/75/16's.
Said airbags,
flagstaff
