Old 07-30-2017, 01:37 PM   #1
mikdor1's Avatar
New Low style Wineguard TV antenna...no reception
Have a 2017 flagstaff with low style antenna. It seems to have poor reception even with booster on. Do they make a better booster?
2017 Flagstaff 524RLWS
2015 F150 , 5.0 , 3:55 axle
mikdor1 is offline   Reply With Quote
Old 07-30-2017, 01:49 PM   #2
I just took delivery on a 2018 Flagstaff and found all but two connections to the antenna loose. The loose ones's were several turns from tight with two (one on TV and one on amp) were only connected by one or two threads.
In my case I had to remove the stereo to get to the connections on the back of the amplifier switch and splitter (for the outside connection).
The Amp is in the antenna itself and loose connections between it and the switch can cause reduced power to the amp. Connections should be TIGHT. Tight enough you can't just disconnect with finger tips.
In my case it improved the number of stations I could "see".
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
antenna, reception
