Old 12-18-2013, 04:35 PM   #11
Timex's Avatar
Update! Update!
After much head scratching, I finally figured things out. Inside the tstat is a switch for GAS/OIL or ELECTRIC/HEAT PUMP systems. Since I have a gas furnace, I flipped it to GAS/OIL and everything is working as it should!
Thanks to all who tried to help. Maybe this will help some poor soul down the road!
Timex is offline   Reply With Quote
Old 12-18-2013, 04:46 PM   #12
jtstromsburg's Avatar
Great! Thanks for sharing your fix
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 12-18-2013, 04:59 PM   #13
Witch Doctor's Avatar
You will still need a jumper from Rh to Rc other then that your ac will not get power. unless it has an internal jumper installed. Rh is power to hot Rc is power to cool.
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-18-2013, 05:04 PM   #14
Timex's Avatar
Like I said, EVERYTHING is working fine.
Old 12-18-2013, 05:38 PM   #15
That's just great that both a/c and the fau is both working without a jumper. That's a first for me being I did HVAC for 20 years, I guess you are never to old to learn. looking at your subase it looks like a jumper wire from R to RC
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-18-2013, 08:40 PM   #16
Timex's Avatar
Had to set the AC at 60* to test it. Couldn't stand more than a few minutes of that but the fan ran on auto and shut off when the compressor cut off. I could turn the fan to ON and it would stay on. The furnace would come on at the set temp and run like it should. No fan ran up top unless I manually turned it on. The only thing I don't have is a switch for HI/LO fan. I just have the LO fan speed, which is fine for me. We use a tower fan in the den. The degree of change looks like a 2* swing. I'm satisfied, better than the 8-10* swing!
thermostat
