Originally Posted by Macrosill
Just add air as needed. Air is about 78% nitrogen anyway.
Not only that, eventually the oxygen in the compressed air will permeate the inner liner and find it's way out of the tire. As more air is added, the same will continue although it will take less air each time. Eventually the percentage of Nitrogen in the tire will climb to around 90% which is pretty close to the max percentage for a Nitrogen filled tire anyway. That is unless the tire is mounted inside a sealed, Nitrogen Only, environment. Kind of hard for the operator to breathe though
