Old 08-20-2017, 05:06 PM   #1
No A/C blowing out vent in bathroom on 2018 microliter 21fbrs just wondering if anyone
No A/C out bathroom vent
Flagstaff Micro is offline   Reply With Quote
Old 08-20-2017, 05:12 PM   #2
markb5900's Avatar
What unit do you have?
Are the vents at the actually AC unit closed or open?
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
Old 08-20-2017, 05:31 PM   #3
2018 flagstaff microlite 21fbrs,,,,I closed vents off at unit and air comes out all the duct vents except the one in the bathroom vent
Old 08-20-2017, 05:34 PM   #4
2018 flagstaff microlite 21fbrs ,,air vents at unit are closed,,,,air out all duct vents except bathroom vent
Old 08-21-2017, 04:54 PM   #5
Thurman's Avatar
Could be the same as what I found on my '15 FR Coachmen Freedom Express 310BHDS: The bath register wasn't even connected to the main ceiling duct work. When I found that I called the selling dealer, some 90+ miles away, and they called back to tell me that there was not supposed to be an A/C register in the bath area therefore they would not correct the problem.
Thurman is offline   Reply With Quote
Old 08-21-2017, 05:07 PM   #6
crunchman12001's Avatar
Remove the vent cover in the bathroom. Turn the flash on your phone and take a picture with the phone up in the vent opening. What do you see?
2015 F-250 FX4
Old 08-21-2017, 08:05 PM   #7
Ok I will,,,probably be tomorrow,,,I looked in there previous and only seen the styrofoam duct work
Old 08-21-2017, 08:09 PM   #8
Trace it down, put a small flashlight up in the AC output side pointing towards the bathroom. Take the picture pointing towards the AC. you should see light in your picture.
2015 F-250 FX4
Old 08-24-2017, 12:32 AM   #9
I have a 2018 microlite 21frbs. I have a/c coming out the bathroom vent. I believe that there is no actual ducting in these units just a tube bored in the styrofoam, there has to be something blocking. Let me know what you find and I can compare it to mine for a reference.
Jrmac22 is offline   Reply With Quote
Old 08-27-2017, 08:53 AM   #10
Ok thanks I will check it out ,,,i was thinking that's all they had it cut out of the foam,,,,in the middle of this Harvey storm tight now,,,we are 20 miles east of Houston
Old 08-27-2017, 09:18 AM   #11
The A/C duct work is Formed into the Roof structure Front to Back,any place they cut a Vent A/C should "Come Out"! Youroo!!
Old 01-17-2018, 11:51 AM   #12
A/C
Originally Posted by flagstaff micro View Post
no a/c out bathroom vent
i have two a/c and they are wired backwards zone 1 is zone 2/ zone 2 is zone 1 and no one wants to make it right.
OLDNO7JF is offline   Reply With Quote
bathroom, lite, roo, vent
