05-14-2018, 04:55 AM
No power from battery
Just brought home our 2017 flagstaff 832 OKBS. Took it out to our storage spot and no power to raise or lower the tongue jack. Everything I’ve been able to research indicates there is some battery disconnect switch. Where the hell is it on this trailer? Any help would be appreciated. Thanks
05-14-2018, 05:06 AM
You may not have a disconnect switch but you will have an inline resettable fuse near the tongue jack. Probably under the tongue. If you have a disconnect switch it will be fairly large and be labeled batt 1/batty 2/both/ on/off etc. Some are in the battery compartment. Some are inside near the entry door. Only two places I've heard of. You must not have one because somebody had to lower it on to your truck. Also, you need the battery to run your emergency brakes I would think.
05-14-2018, 05:42 AM
I sure hope there’s a battery disconnect switch there because I can’t think of any other reason why I have to be plugged into electrical power to operate anything.
05-14-2018, 05:52 AM
Read my post again. You may NOT have a disconnect and you DON'T need to be plugged in to operate Tounge jacks, slides, and levelers because they have independent IN_LINE fuses from the converter so you can Boondock.
05-14-2018, 06:09 AM
If you have to be plugged in for jacks to work your battery is disconnected or dead or maybe gone.
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
05-14-2018, 07:00 AM
This is the tongue jack right? They’re typically not wired direct to a disconnect unless the disconnect is right there at the battery.
More likely, it’s just an inline fuse. I kept blowing mine on my tongue jack the first season until I learned not to run the jack either all the way up or down. If you run it until it stops, that usually has blown the fuse. From the jack, trace the wires back to your battery box, most likely you’ll find an in-line fuse holder. Open that up and check the fuse. If it’s blown, replace.
If you’re stuck at the storage lot and don’t have a spare fuse on hand, there should have been an option for a manual override to crank it down.
05-14-2018, 08:38 AM
Is this a new unit?
Did it ever work?
If new, the dealer should have explained the disconnect and had the battery charged.
If not, you will need to check for some of the things mentioned.
Do you have a multi-meter and know how to check for voltage at the jack switch?
05-14-2018, 08:45 AM
If I read the OP correctly, this just came out of storage and you are not sure if you have a battery disconnect switch. From this I assume you did not turn off the switch before you stored it. If this is the case the battery is dead. That being said. you may be able to connect to the TV to get power or plug the TT into shore power. In either case, if the battery is toast, you will most likely trip/blow the resettable breaker or reverse polarity fuses in distribution panel. If you stored in a freezing climate, check the battery as it could have cracked. Try removing the battery and charging it with an automotive charger.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
05-14-2018, 08:53 AM
Flybob, I'm reading (blue) they just brought it home (from dealer or wherever) and were in the process of taking it to the storage lot. (red)
Maybe the OP can clarify.
05-14-2018, 12:03 PM
Another example of a lousy PDI from the dealer.
Very basic thing that should have been gone over.
The disconnect switch on new Rockwoods is along the A-frame, under the battery.
05-14-2018, 12:09 PM
Did you find or look for the fuse under the frame yet? When it was put on your truck it was probably run to the stop and tripped the resettable fuse I told you about earlier.
05-14-2018, 12:33 PM
I have a 2016 832 IKBS the Battery disconnect is directly under the Propane tanks. It is mounted on the cross member there. The resetable breaker is in a metal box about 3 feet aft of the battery on the drivers side frame rail. You will need a #2 Phillips to open the box.
Attached is a picture to show what my disconnect looks like. The little black box in the lower part of the picture is the break away safety for the trailer, not the fuse for resetting the electric tongue jack.
Hope this helps.
05-14-2018, 12:34 PM
Sorry did not load,
05-14-2018, 02:37 PM
Thank you all for the replies. I went home for lunch and sure enough there's a battery disconnect switch up underneath the propane tanks. It's amazing how much battery power you have once you turn that switch on. LOL
Very disappointed that they didn't point that out to me Saturday when we picked it up at the dealer. Again, thanks, one and all.
05-14-2018, 02:41 PM
What a shame your dealer did such a poor job explaining things to you.
If they didn't show you something such as a disconnect switch, there will be other things too that you will question.
Come back as often as needed and we'll try to help out.
05-14-2018, 02:58 PM
Put some stop marks on the jack. If you run it up it stops by itself you will trip it again.
05-14-2018, 03:48 PM
Just as confused as you
If you cannot find a fuse in-line for the jack you may have one inside the jack motor housing. That is where mine is, the housing has to come apart to get to it.
Richard & Jill
05-14-2018, 04:02 PM
Was not the breaker, but rather the battery disconnect switch.
TST Tire Monitors
2 100W solar panels
05-14-2018, 04:32 PM
Not the same TT, but our battery disconnect looks like this and is on the frame next to the battery. I believe the "key" (red thing) has to be in the housing to charge the battery from the tow vehicle. The key turns to the right to lock in, left to remove. When removed it might be hanging from a short wire nearby. There is a separate fuse for the tongue jack somewhere under the jack, but so far never had to look for it.
2016 Rockwood 2504s
2016 Chevy 2500HD
05-14-2018, 10:29 PM
Bingo. That hit the issue. Converter or no. Oh and the guy who asked if there was a battery, cause in our parts they darn near steal stuff while you're driving down the road.
Wow, and I eat my words. Never saw one not just wired direct to the battery with a line fuse.
Tom48
In Sunny So Cal /w
Now in 2005 Holiday Rambler Ambassador DP and The Hot Air Balloon RESTLESS
NO MORE Tricked out
2017 Sandstorm 250 T.H.
