Old 12-06-2015, 04:23 PM   #31
Instructions to add a small switch to a big box store digital thermostat (Honeywell, etc.) to allow you to select both fan speeds can be found here.
An easy modification.
RVP Thermostat Replacement with Digital Honeywell Thermostat - RVTalk Forum
2017 Berkshire XL 40A & 2017 Ford Focus SE
2014 Flagstaff 5th Wheel - 8528IKWS (Sale PENDING )
I Built and Fly - Van's Aircraft RV-12
MartyQ is offline   Reply With Quote
Old 12-11-2015, 09:19 PM   #32
Had the same problem with our 2015 Rockwood 8289WS. Removed screws to get to the furnace and found a huge tear in one of the flex ducts going to the main cabin. Made repairs and all is well so far. Hope this helps.
dcnky is offline   Reply With Quote
Old 12-12-2015, 04:13 PM   #33
G.B.'s Avatar
We notice that the bath and bedroom are warmer than downstairs. Not near as dramatic as others have posted. I'm for sure going to swap out the thermostat for the digital one to help keep temps more steady. I've found that using the fireplace and a ceramic heater downstairs helps a bunch too.
Greg & Patty
2014 Flagstaff 8528IKWS
2004 Chevrolet Silverado 2500HD Extended Cab 4x4 Duramax/Allison
G.B. is offline   Reply With Quote
Old 12-12-2015, 06:46 PM   #34
polymark's Avatar
The furnace in these units put out a fixed amount of air volume. You should have vents with the flaps in them to regulate the amount of airflow to each vent. You need to vent more air flow to larger areas. The other thing that you need to do is add some insulation in the ducts to help transfer the heat. But air balancing will help make things feel for comfortable.
polymark is offline   Reply With Quote
Old 12-12-2015, 06:53 PM   #35
Left Coast
You can also move the duct hoses around...from outlet to outlet
Old 12-12-2015, 07:04 PM   #36
camping baba's Avatar
We have a 8280 with the same problem . In the spring I will be installing dampers in the ducts lines to the bathroom and the vent at the top of the stairs . There should be enough air flow not to overheat the furnace . All the supplies are at the big box stores .
2013 Silverado extended cab 4x4 1500 Series
camping baba is offline   Reply With Quote
roo
