Originally Posted by teamgl
that heater u are using puts out around the same if not a little less then the heater element - someone told me the heater element puts out about 1500 to 1600 watts so it is compareable to what you are using.
I think I paid just under $50 from PPL in Texas - Might be worth a shot to upgrade then you will have both the heater element and the cabin heater when you have electricity and run the gas one when you dont.
i got a quick question for ya - if it drops below 50 degree's does your inside heater kick on by itself even when the thermostat is in the off position (far left side)?
a few weeks ago it was around 35 degrees or so and inside my camper the heater was set to the far left - it is a black thermostat on the wall just under the TV and when I put the battery power on the fan for the heater kicked on and never went off - wondering if you have ever experianced that. I had the gas turned off so I knew the fan would have just kept blowing cold air.
