Old 04-14-2012, 02:58 PM   #1
Steve Jackson
sideout1961's Avatar
Outdoor Shower
As anyone ever put in shut off valves for the outside shower? Hooked up the water to the camper for the first time(new trailer) and the shower was leaking. Had to take off knobs and think I managed to adjust it right but started to think what if something gave out on the shower there would be no way to stop the water except to turn off main and then your stuck with no water to unit. Just wondering if the is anything out there I could install.
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
sideout1961 is offline   Reply With Quote
Old 04-14-2012, 03:13 PM   #2
TURBS's Avatar
Just shut your pump off when not in use also
Old 04-14-2012, 03:29 PM   #3
Steve Jackson
Do you still use your pump even if your hooked up to city water? I didn't have mine on when I was testing everything out.
Old 04-14-2012, 03:31 PM   #4
TURBS's Avatar
No the pump is not used with city water hook up.
Old 04-14-2012, 04:10 PM   #5
Did you have a pressure regulator connected to the city water hose. The RV plumbing should not go over 40 - 50 psi and city water can be much higher. My house water pressure is around 80 psi. This can cause a leak or worse burst hose.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 04-14-2012, 04:19 PM   #6
Dave_Monica's Avatar
The outside shower is no different than any water outlet in the camper...none of them have isolating valves.
Dave
Old 04-14-2012, 04:30 PM   #7
We just cap the two lines, we never use the outside shower. Did this on the 08 831RLSS and re-installed it when we traded it in. Someone got a brand new 4yr old shower assy.
Old 04-14-2012, 04:50 PM   #8
itch'n to road trip
campnqueen's Avatar
Send a message via AIM to campnqueen Send a message via MSN to campnqueen Send a message via Yahoo to campnqueen
We had shut off valves added to out outside shower. We do winter camping and did not want to de-winterize our outside shower.... don;t REALLY use the outside shower in the winter.... it's a little brisk :O
2012 Ford F-250 King Ranch Super Crew Cab 4x4 "Mae West"
2014 Work & Play 25ULA "Ula"
Paula Drake, Ken Cooksey, Sunny Delight & Valor
Jasper Ga.
campnqueen is offline   Reply With Quote
Old 04-14-2012, 05:39 PM   #9
TURBS's Avatar
Fyi if you don't use your outside shower it remains
Winterized untill you do.
