10-02-2015, 06:36 PM
#21
Recommended gas grill to buy? I don't know if it has a propane line for grill.
10-03-2015, 07:14 AM
#22
A lot of good vets on here. On s trip what is a good amount of time to travel on one day. Don't want to over do.
10-04-2015, 04:05 PM
#23
Owner of a 2016 Flagstaff 8528 IKWS!!!!
We have had the rear kitchen model now for 1-1/2 years, 5500 miles towing with an F150. We love ours, but I would suggest the extended warranty. The roof had to be replaced completely after 8 months, problem with shower door, rear stabilizer switch, new freezer door ... All covered and actually repaired at Camping World, but can see that the extended warranty will be a good investment.
We just bought a Coleman Roadtrip XLE grill. The original optional grill did not hold up well at all.
2015 Flagstaff 8528RKWS
2013 Ford F-150 Ecobeast
10-06-2015, 03:07 PM
#24
Long day but we are all hooked up at a nice KOA. Dealer did a great job at PDI and explained all. Quick driving lesson and now relaxing at our site. Everything seems to be working
Tired and relaxing in our Lazy Boy chairs. 90 outside but comfortable inside.
10-06-2015, 03:26 PM
#25
The recliners are nice! Enjoy!
#26
Enjoy! Nothing like setting back and taking in all the joys a new unit can offer.
10-06-2015, 04:31 PM
#27
It seems the hot water is very warm Is that expected? I don't believe we can regulate the temperature.
10-06-2015, 04:45 PM
#28
Yes, the water is "HOT". I was told there is no adjustment. I see you are in 90 degree temps. so, my comments about the furnace in the 8528IKWS probably don't mean much to you but, we have found that the furnace does not put adequate heat in the living room and too much heat in the bedroom/bathroom.
2015 Flagstaff 8528IKWS Diamond Package
2013 Ford F-150 Super Crew, EcoBoost, Max Tow,
6.5 bed, Roadmaster Active Suspension, E rated tires
98 days camping 2017 98 days camping 2018
94 days camping 2019 49 days camping 2020
10-06-2015, 07:49 PM
#29
I've noticed the imbalance of the heat in the front. I will cover one of the registers on the next trip in a couple of weeks to see if that helps. In the moderately cold temps, we use an electric heater, rather than the gas. We were using the gas while dry camping in Shenandoah.
10-06-2015, 07:59 PM
#30
We have a little bit of a rocking sensation when walking around. Do I need to check interior floor with level to see if I'm level back and front?
10-06-2015, 08:15 PM
#31
Make sure your rear stabilizers are down. I usually run mine until they slightly lift the rear of the camper, maybe an inch. Also, a hitch tripod stabilizer helps.
I actually use a torpedo level on my counter tops to level by. I watch the level and my wife operates the front jacks.
10-07-2015, 08:44 AM
#32
You probably haven't had the opportunity (and the dealer probably didn't as well) to install bubble levels to use during set up. If you've set up and didn't check level, you really should. It helps the refrigerator work better and the slide outs won't be on a bind when extending or retracting. (you'll find other reasons too why level is better!)
As far as the rocking sensation, as mentioned make sure you have some weight on the stabilizers. Remember they are not designed to lift the unit off the ground, just stabilize.
Even with the front & rear stabilizers properly extended, many 5th wheelers still complain about the jiggling. A forum search will turn up many, many discussions about this.
Some use an extra set of jacks/stabilizers near the center of the unit, some use a hitch pin jack, and many are now going to one (or more) of the several available types of cross bracing methods for the built in jacks/stabilizers. Most say the x-brace wheel chocks help a lot too.
Especially with a new unit, each trip will be a learning experience. Enjoy!
10-07-2015, 01:22 PM
#33
Sewer question for when we leave tomorrow. I want to make sure all water is drained including fresh water holding thanks and water heater. What are the steps in order? Thanks.
10-07-2015, 04:14 PM
#34
We are in our second year with our 8528 IKWS. Had to replace the front end cap (warrantee) and roof (tree limb). But we use a great shop and all that said we still love our Flagstaff! Hyper vigilant about tire pressure and keeping them covered. I'll replace the China bombs next spring for peace of mind if nothing else.
Greg & Patty
2014 Flagstaff 8528IKWS
2004 Chevrolet Silverado 2500HD Extended Cab 4x4 Duramax/Allison
10-07-2015, 05:09 PM
#35
What kind of tires?
10-07-2015, 05:40 PM
#36
What kind of tires?
It has the Trail Express Power Touring S/T tires in it now. I'll probably go with the Maxxis ST tires in load range D.
Greg & Patty
10-11-2015, 07:31 AM
#37
Getting back up fuses. Forgot to ask. What is the most common size and what sizes are needed 15 20 or 30? Same fuses as cars correct?
10-17-2015, 12:09 PM
#38
Another question for you. I just received my tag in the mail. I'm putting on the back of the Flagstaff. Is the plastic threaded stuf and plastic nut strong enough to keep the plate secure? Thanks again love my 5th wheel.
10-17-2015, 12:14 PM
#39
I use stainless steel bolts, flat washers, and stainless steel self locking nuts.
10-20-2015, 01:17 AM
#40
Tuskstar
buying a 2014 8528ikws diamond. pulling with a f150 4x4 screw. pullrite superglide. any suggestions? My first RV. Getting excited about going Camping.
