Old 10-20-2015, 08:06 AM   #41
Pickin' & Campin'
Enjoy!
Don't forget your RV will have the Reese Revolution pin box. No need for a slider unless you want it.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 10-22-2015, 04:19 PM   #42
OswegoLion's Avatar
Anybody use the gas grill that came with unit? Mine came without instruction on setting and hooking up to propane. I'm not sure if I'm going to use it or get the Coleman Road Grill
OswegoLion is offline   Reply With Quote
Old 10-22-2015, 04:36 PM   #43
Georgia Frog Rally 2018
aceinspp's Avatar
Nope don't like. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 10-22-2015, 06:37 PM   #44
LTnTN's Avatar
Mine barely lasted a year. Coleman Roadtrip XLE now.
2015 Flagstaff 8528RKWS
2013 Ford F-150 Ecobeast
LTnTN is offline   Reply With Quote
Old 10-22-2015, 07:43 PM   #45
Wayne Joan's Avatar
We have used ours several times. I have used better grills but, it works and is handy to haul around.
2015 Flagstaff 8528IKWS Diamond Package
2013 Ford F-150 Super Crew, EcoBoost, Max Tow,
6.5 bed, Roadmaster Active Suspension, E rated tires
98 days camping 2017
86 days camping 2018
Wayne Joan is offline   Reply With Quote
Old 10-23-2015, 05:14 AM   #46
OswegoLion's Avatar
What type of hose and connector did you use to connect to the 5th wheel propane supply?
Old 10-23-2015, 08:40 AM   #47
LTnTN's Avatar
There is not a standard hose made. I watched a video on YouTube named "Connecting a Coleman LXE Roadtrip to a low pressure trailer quick connect."
I'm still currently running mine on the high pressure bottle, but will order extra parts from Coleman so that I can use mine either way when I build the adaptor. I'm also going to make an additional shelf from the old grill's mounting rail/bracket on the side of the RV.
Old 10-23-2015, 09:40 AM   #48
Wayne Joan's Avatar
The hose that was in the box with the grill.
Old 10-23-2015, 10:06 AM   #49
OswegoLion's Avatar
Ok sorry for prolonging this topic. The grill that came with the Flagstaff did not include a hose or connector. Does the propane supply on 5th wheel have a hose that stretches and connects to grill?
Old 10-23-2015, 10:27 AM   #50
Wayne Joan's Avatar
I think you need to go back to your dealer and have them get you a new grill or at least all of the things that should have been included in the box your grill should have been in. They also should show you how to hook it up. There is a propane connection (valve & quick disconnect) under the trailer just, rearward of the of the dinette slide out. I hope you are able to resolve this with your dealer.
8528, flagstaff
