Old 02-20-2013, 11:33 PM   #1
Panel Damage, Replacements, DIY, 831RLBSS
Flagstaff 831RLBSS, have a damaged panel, between rear wheel and bumper on left side, and the panel taht goes across rear underneath the bumper. Can one order these panels from Forest River and repalce them yourself?
POC, source please.
Thank you,
Wanderer
"All who wander are not lost"
2008 Cardinal 30RK fiver.
2009 Chevrolet 2500HD DuroMax
2009- 42 days; 2010-40 days, 2011- 40 days. 2012- 30 days,
2013- 14 days, 2014- 21 days, 2015- 42 days
2016-17 days, 2017-zero days
Wanderer is offline   Reply With Quote
Old 02-28-2013, 03:44 PM   #2
Parts
Our 1 week old trailer got broken into this past Sunday and I called Forest River to order some new parts and they were able to find the replacement parts. Don't expect fast service, however, they took my order and 24 hours later, I'm waiting on a call from the shipping department so I can make payment on the order. You will need the last 6 of your VIN so they can look up the parts for your unit. Try Suzanne at 547.642.0366. She is the only person in the Flagstaff Lite parts division and she will eventually call you back.
Good luck
Babygiz is offline   Reply With Quote
Old 02-28-2013, 04:12 PM   #3
DAISY BOYKIN's Avatar
I also replaced a panel--------
Wanderer, I damaged a (gold) panel on the right front of a 8285 WS fifth wheel for making a too sharp at a gas pump. I called my warranty contact at Forest River, supplied VIN number. The part was not cheap, was made out of aluminum, already painted. Because of size, it was truck shipped. It was rolled for the right shape, but I had to hand trim the new one for the correct fit. The old one was about 7 feet long, but the replacement was 8 feet long. My suggestion, if you have to trim the new one to fit. just lay the old one down on top of the new one, mark around the old one with a felt marker. Make sure if any trim is removed, you place the gray putty on each screw hole to stop water seep into the siding.
Good luck on the new job as sheet metal mechanic!!!!!
Sid, Lois & HRH MISSY Terrible 3s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2018 60 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 02-28-2013, 04:59 PM   #4
I thought it would be much more difficult than a phone call. Thanks for the tips.
2011 Forest River Georgetown 350ts
Where We Have Been
RV Guide for rv mods and rv tips
halibut3 is offline   Reply With Quote
Old 02-28-2013, 09:46 PM   #5
Thank You for the info,
Appreciate it.
Wanderer
