Old 05-29-2019, 03:17 PM   #1
Pin box issue
I own a new 5th wheel Flagstaff super lite 529BH that came with a lippert trailair turning point pin box. I do not like the jerky back and forth motion when towing. I would like to replace this with a MORryde. Does anyone know which model of MORryde fits this rv?
Blynd loop is offline   Reply With Quote
Old 05-29-2019, 03:24 PM   #2
Not sure what you are referring to when you say "jerky back and forth motion when towing"?
If your 5th wheel is swaying wildly when towing, something is not right with your set-up.
Maybe the turning point needs lubed or the wedge isn't tight enough... or... maybe you have axle issues.
Throwing another pin box at it may not solve your issues.
Have you tried towing with it in the locked position?
Days Camped: '16=46 '17=30 '18=51 '19=42
Old 05-29-2019, 06:13 PM   #3
Locked is the only way I tow it. When i pulled my older 5th wheel with the MORryde you would never feel the jerky motion. It pulled like you had nothing behind you. This rv is the same length and a bit lighter.
