Originally Posted by cpd1343
I found not only loose connections but improperly installed F connectors. I ended up replacing almost all the cables.
While I had the stereo out to research for another project I found all of the coax connections not even finger tight, several were not more than one or two threads onto the connector. Also noticed this at delivery with the connection to the TV but didn't think of having them check the ones inside the compartment behind the stereo.
Since the coax also carries power to the amplifier in the antenna it's essential that the connectors from amp switch/wall connector to the antenna be solid electrical connections.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
