Old 07-20-2017, 09:13 AM   #1
sgskad's Avatar
Poor to no Television reception
we have only been out with our new 25BDS twice and not real big on TV while camping, but both trips we did have some light bouts of rain and while hanging out indoors waiting on the rain to stop we tried the TV and neither time were we able to get and sustain any channels............ is there something we are doing wrong or something else we should consider adding to get some reception?
Scott and Kristina
brand spankin new 2018 Flagstaff 25BDS
Flagstaff 227 popup, sold to my son
sgskad is offline   Reply With Quote
Old 07-20-2017, 10:11 AM   #2
Kasual Kamper
It depends on where you were. There simply may not have been any stations broadcasting that were a reasonable distance away. Also, did you rotate the antenna? Try it in your driveway.
JayArras is offline   Reply With Quote
Old 07-20-2017, 10:22 AM   #3
Oakman's Avatar
Did you turn on your antenna booster?
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 07-20-2017, 10:25 AM   #4
Flybob's Avatar
If you have the antenna shown in the attachment, the only thing it has in common with a TV antenna is the shape. If tv is important consider replacing it with a King Jack, If you only use occasionally, you can use a stand alone an external antenna. Rain and trees are not digital tv friendly. Make sure you have the amplifier on ( small button on coax wall jack).
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-20-2017, 01:44 PM   #5
Air Force Retired
If your unit is new, you may want to check the inputs on the back of your TV. Mine were mis-installed with everything moved over one jack. I got poor reception and no DVD. It was an effort to redo mine since the TV comes out of the counter but after proper installation, everything works fine.
poppagary is offline   Reply With Quote
Old 07-20-2017, 01:53 PM   #6
Make sure that the booster is on (little red light on mine) and go into the TV menu and scan for channels whenever you are at a new location.
2017 Surveyor 245BHS
chadande is offline   Reply With Quote
Old 07-20-2017, 02:33 PM   #7
The nature of many campgrounds is that they are way out of town, so antenna Tv reception may be spotty or none. That is why you see many of the campgrounds are offering cable. If I'm camping in a place that doesn't offer cable, I carry some DVDs.
Rita B
2016 Surveyor 201RBD
2006 Jeep Commander 5.7 Hemi
Camping
2017- 27 days,2018- 100 days, 2019- 35 days
RitaB is offline   Reply With Quote
Old 07-20-2017, 02:47 PM   #8
Send a message via MSN to Tiggerdad
Some are green
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 07-20-2017, 02:50 PM   #9
ColoradoRick's Avatar
As already stated, ensure the power boost button is on and that it's wired correctly. (And let it do a scan.)
Since we mostly camp in wooded areas in Colorado, the TV antenna is rarely even raised. (Even when close to a town, reception is usually horrible.)
But we do have a stash of "rainy day" DVDs if we get stuck inside and occasionally will grab a few DVDs at the store when picking up supplies for the next camping trip.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 07-20-2017, 03:15 PM   #10
No one has told you where the booster switch is located. The booster switch and LED are located on the wall plate that your TV cable plugs into. The LED is not very bright, you have to look closely to see it sometimes.
2011 Traverse LT, 3.6L, FWD
Old 07-20-2017, 03:45 PM   #11
BobHanke's Avatar
As others have said, check connections and make sure booster is on when using rooftop antenna. Next use a locator website like this to find where the closest stations are: www.antennasdirect.com/transmitter-locator.html Then aim your antenna to the stations you want, set the TV for Air and scan for channels.
"Lurch" = Georgetown 2011 330TS
Toad = Jeep 2016 Cherokee
Pilot = Bob
Navigator = Xiangbing
Crew = NaNa & NiuNiu
BobHanke is offline   Reply With Quote
Old 07-20-2017, 05:05 PM   #12
OLDNAVY's Avatar
I had same problem with my King Jack. Took it back to dealer and he stated it was wired wrong. He stated 80-90% of the units have faulty wiring. Check on that
OLDNAVY is offline   Reply With Quote
Old 07-20-2017, 06:30 PM   #13
rockfossilman's Avatar
I've used that locator website, but have have had better luck with: https://www.fcc.gov/media/engineering/dtvmaps Once the map opens, you can zoom in and move the Location Teardrop to the exact location of your campsite. I use Google Maps to find the precise campsite location first. It doesn't take much elevation change to add or eliminate a Digital Station from your options.
We had trouble with reception at a campground in Ohio last week where stations should have been available. I went on the roof and checked the connection under the boot where the cable and found it was loose. After tightening it up, all the stations that the FCC website said should be available, then came in.
The booster light on our system is green.
Rockfossilman - Western PA
Rockwood UL 2604ws - 2013 F150 w/MaxTow
"I'm a man, but I can change, if I have to. . .I guess."
Red Green
"Quando Omni Flunkus Moritati"
rockfossilman is offline   Reply With Quote
Old 07-21-2017, 11:41 AM   #14
Canadian Member
Further to Rockfordroo's post, this is the wall plate. The Booster is activated with a the small button to the right of the cable connectors. A red or green light should come on if the booster is powered. Assuming you have a Winegard Sensar antenna, you can add the Wingman attachment which does help improve reception.
Name:	Wineguard RV-7542 Wall Plate.jpg
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
Old 07-23-2017, 11:41 PM   #15
Rangie's Avatar
We use an Amazon Firestick, pending the campground has wifi or you have unlimited data on your phone then you can use your hotspot.
Rangie is offline   Reply With Quote
Old 07-24-2017, 08:11 AM   #16
Kasual Kamper
Streaming video over a campground's wi-fi slows response for everyone else and is likely to be a frustrating experience to boot!
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
Old 07-24-2017, 08:24 AM   #17
2017 Windjammer 3029w
We rarely get over the air channels whil camping, so we went with Dish Network portable satellite system. They have portable systems that find the satelites automatically and can watch same channels as we have at home, even locals if not to far away from home. Locals are lost if distant area from your home. We have Dish at home however, and use a bedroom receiver from our home so that no extra cost is incurred each month. DirecTv has similar systems.
Dastagg is offline   Reply With Quote
Old 07-24-2017, 08:38 AM   #18
I found not only loose connections but improperly installed F connectors. I ended up replacing almost all the cables.
Les & Heidi Kramer
2010 GMC Sierra SLE & 2014 Shamrock 23IKSS
Cleveland, OH
cpd1343 is offline   Reply With Quote
Old 07-24-2017, 08:46 AM   #19
rsdata's Avatar
Even in a good-signal neighborhood it is inadvisable to put a UHF antenna behind a tree. The farther away a tree is, the less of a problem it is. For far away trees, assume no signal penetrates the tree, and reception will be by diffraction around the tree.
Unless your antenna is higher than surrounding trees your signal from local TV stations will be hampered.
Too much of anything is bad, but too much good whiskey is barely enough. Mark Twain
2014 Shamrock 183
Old 07-24-2017, 08:50 AM   #20
ben31's Avatar
Did any of the suggestions work??
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat SuperCrew 4X4 6.4 Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
reception, television
