Originally Posted by Tntbatta2008
Plugged into power. Definitely not a power problem. The awning does stay up when out so thank you for the shock reply. It must be the motor.
Motor is 5 years old and Is suspect to weather.
Most likely the motor is getting bad.
Fyi.
DO NOT attempt to remove motor yourself unless you know what your doing.
Awning spring is under great pressure.
Turbs
Btw welcome to the forum.
