09-17-2018, 11:09 AM
Power stabilzers not working
Not sure if this thread will suffice-- couldn't find better one----Anyway my rear stabilizers would not power down, so I got the crank handle and manually lowered them. the power button to retract them up works!! but no power to lower.Any ideas on a fix??
09-17-2018, 11:11 AM
Commercial Member
Yehhhhh...I think you're in the wrong spot. I would start a new thread with that question as this one has nothing to do with that.
I would also suggest giving a model number of what type of unit you are referring to. Isata 3? 24FW?
Nevermind..I found it in your details. You have a Flagstaff trailer and are posting in a Dynamax Motorized sub-thread.
I would go here...
http://www.forestriverforums.com/forums/f33/
and either search or post a "New Thread"...button is in the upper left hand side when you are in there.
09-17-2018, 11:19 AM
I would go here...
Let me get to a computer and move these posts.
2011 Flagstaff 831 RLBSS
09-25-2018, 12:50 PM
Has to be the rocker switch, because it sounds like there is power getting back there. Should be an easy fix
2018 Flagstaff 831BHWSS
Custom Yukon XL 2500 Duramax conversion. Tuned, deleted, and other goodies
09-25-2018, 02:28 PM
... my rear stabilizers would not power down, so I got the crank handle and manually lowered them. The power button to retract them up works!! but no power to lower.Any ideas on a fix??
As mentioned above it's most likely the rocker switch. They're pretty easy to replace if you're somewhat handy. Just take a photo of how it's wired on the back and replicate that on the new switch.
If you need suggestions on where to get a switch, post back with a pic of yours and we can help you locate one.
Gotta go campin!
09-25-2018, 02:38 PM
If the switch is suspect you can jump across it with a small piece of wire or clips to test it
09-25-2018, 03:21 PM
If it is like mine it is switch and mini breaker combined.
2015 Flagstaff 8528IKWS Diamond Package
2013 Ford F-150 Super Crew, EcoBoost, Max Tow,
6.5 bed, Roadmaster Active Suspension, E rated tires
98 days camping 2017 98 days camping 2018
94 days camping 2019 49 days camping 2020
09-25-2018, 03:35 PM
Auto reset breaker? Youroo! !
09-25-2018, 04:03 PM
Yes, I think you are correct. Had to replace mine.
