Old 02-15-2014, 08:48 AM   #11
Taranwanderer's Avatar
Originally Posted by Mikegjax View Post
Not much of pain, but less weight and since I refill them I don't see an environmental problem. The cost is about 50 cents a bottle.
Agreed. I can fill several of the 1# bottles from a 20# tank at home much cheaper than buying the 1#-ers at Walmart, and then I don't have to carry the extra weight of the 20# tank with me. Chuck them in the truck bed when they're empty, take 'em home, and refill again. They're only environmentally unfriendly when you throw them away after one use.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 02-15-2014, 09:25 AM   #12
TURBS's Avatar
X2
I use a "shnozzle" to refill my tanks for my converted coleman lanterns.
http://www.amazon.com/gp/aw/d/B00EV59S1W
http://shnozzle.com/
TURBS
Goshen is my playground.
The last man standing also has a sharpie
Old 02-15-2014, 09:28 AM   #13
NELA
Weezer's Avatar
I knew I'd seen this discussed previously here:
1 gallon propane tank
You folks are a lot braver than I am with these little propane bottles. Sheesh, when we have one partially used I ask DH to take it *way* out back and store it on a utility trailer far, far away from anything.
We take only brand new/un-used bottles with us camping. They're cheap enough and I don't want to risk leakage.
I saw a 4 lb refillable tank on a "cookie ad" when I was doing a Google search just now and can't find it again. Now that's something that would interest me. It looked just like our tanks on the 5er, just very small. IIRC it was something like $54.00.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 02-15-2014, 09:32 AM   #14
NELA
Weezer's Avatar
Here it is;
Refillable Steel Propane Cylinders-4.5 lb. / 1 gal. - Worthington Cylinders 281149 - Propane Cylinders - Camping World
Another item for my 5er accessory want list. If I buy it now can I convince him it's a day-after-valentine's day gift for us both?
Old 02-15-2014, 09:33 AM   #15
dcheatwood's Avatar
Our local lp supplier (Southern LP) has a wall full of hoses and connectors, along with cookers, heaters, etc. They're very knowledgeable and s quick stop in one near you may provide the info you need.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 02-15-2014, 09:35 AM   #16
NELA
Weezer's Avatar
Originally Posted by Wiscampsin View Post
When we had our popup I didn't like the idea of using the RVQ grill hooked onto the sidewall. I took the short hose that came with the grill to a local LP place and they put together a 10' hose. I brought along the short hose that came with the grill so they could put the correct quick connect ends on.
Wiscampsin I like this idea too! We have the Char Broil Tru Infrared grill that uses those scarey 1lb jugs. Now to figure out if the fitting for the RVQ would be the same as the Char Broil.
You guys are probably laughin at me, but seriously those little green buggers give me the heebeejeebees.
Old 02-15-2014, 09:40 AM   #17
NELA
Weezer's Avatar
I'm wondering if there are actually EPA regulations regarding the disposal of the little 1 lb cans. May be something on printed on the label...I just never thought to look.
Back when XH and I had the A/C business we were required to punch holes in the Freon bottles before disposal. Two reasons; landfill safety and people were still trying to convert (after they became non refillable) to air bottles for flat tire situations stored in their trucks or car trunks. Don't DO IT!
Old 02-15-2014, 09:51 AM   #18
WFD
Taranwanderer.....do you use the "shnozzle" to refill your 1lb'ers as well? Looks like a handy tool...I never knew they existed.
Rick
WFD is offline   Reply With Quote
Old 02-15-2014, 10:12 AM   #19
KyDan's Avatar
No one here has addressed my post.
I -think- the weber grill the OP is asking about is made to run at
full (disposable) tank pressure.
If he connects it to his RV LP system he will have reduced pressure
and the grill won't work.
Or not- I'm not sure. Anyone with one of those grills- does it have it's
own regulator or not??
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 02-15-2014, 10:20 AM   #20
Kaadk's Avatar
As far as I know, aside from the RVQ all other portable grills come with a regulator. I remember a thread last year about somebody doing a mod to a Coleman BBQ to bypass the regulator and allow it to run on the Trailer's quick connect, but I'm having trouble finding it searching within the iPad app. I think that thread had a side discussion of the Weber as well.
There's no use crying over spilt milk, unless it's on your keyboard.
propane
