Old 10-10-2007, 06:55 PM   #11
RAC
this thread.
RAC is offline   Reply With Quote
Old 01-03-2008, 09:57 PM   #12
Send a message via AIM to DonB
on our 08 GTSS, the hoses both became blocked. Dealer replaced them. I did have to prove to them by removing them and blowing with compressed air (100psi). No passage. Im not currently impressed with my service dept, but am giving them benefit of doubt,,, for now.
05 GMC Sierra 1500, 08 Flagstaff GTSS.
3 Bulldogs, and if you see us on the road, we are probably going to or comming from a dogshow!
DonB is offline   Reply With Quote
Old 06-27-2010, 05:20 PM   #13
It seems I have two blocked hoses also. We tried to use a compression and it didn't seem that much of the air was coming through either of them. How much pressure should should be enough to allow the valve in the hose (I believe there is one) to open?
The tanks are full and I am able to run my BBQ from the tanks.
We changed the regulator and no change, that is when we started looking at the supply hoses. I haven't tried changing them yet but we get no flow when using an air compressor set to around 70 psi.
bobofet is offline   Reply With Quote
Old 06-27-2010, 08:24 PM   #14
I had blocked hoses last year. Hoses from tank to regulator were changed and all was well. Thank you Camping World, Syracuse, NY, for the fix.
Palomino G210
Dodge Ram 1500 Crew Cab
Kayaks
Palomino_G210 is offline   Reply With Quote
flagstaff
