Old 07-18-2019, 08:13 AM   #1
kdot's Avatar
Quality Control?
We just bought a new E -Pro 19FBS. On the first camping trip, the trim strip on the front of the stove fell off and the bathroom switch plate was found on the floor. Also, the cap broke off the storage pipe for the waste tank drain hose. On the second trip, I discovered that the toilet would not hold water due to a crack all the way through the valve that seals the bottom of the bowl. Coincidentally, this also caused the exhaust fan to draw air directly from the black tank and stink up the bathroom. And, I learned that to raise and lower the shades, you have to grasp the shade fabric, not the plastic grip across the bottom of the shade. If you pull the shade down by the grip, which seems logical, the entire gripping strip comes off the shade. Fortunately, the dealer repaired the problems. I hope this is the end of them, but I'm not holding my breath!
2019 Flagstaff E-Pro 19FBS
2017 Honda Pilot
kdot is offline   Reply With Quote
Old 07-18-2019, 08:30 AM   #2
This stuff is pretty common with new FR products.
Glad your dealer took care of you, owning an RV comes with the expectation you are handy with repairs after the warranty runs out.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 07-18-2019, 08:39 AM   #3
You will likely find several more things as time goes along. It comes with owning a R/V and just the way the R/V industry is.
Could it be better?... sure but sadly... it isn't.
As mentioned, you either have to be somewhat handy or have a good dealer/mobile tech to support your issues.
Days Camped: '17=30 '18=51 '19=58 '20=21
Old 07-18-2019, 08:39 AM   #4
kdot's Avatar
Quality control
Yes, I know the stuff is common, although having to replace an entire toilet seems over the top to me.
2017 Honda Pilot
Old 07-18-2019, 08:50 AM   #5
Well anything can/does break or has issues.
You are only ruffling your own feathers if you believe things don't/shouldn't have issues.
Old 07-18-2019, 08:53 AM   #6
kdot's Avatar
Quality control
Well, they are my feathers to ruffle if I choose to.
2017 Honda Pilot
Old 07-18-2019, 08:55 AM   #7
DFW Rusty's Avatar
We have all been there. I spent the first year bad mouthing our last camper, but soon came to terms with the fact that campers are not made to the same standards as a car, house or even a motorhome. Everything has to be as light as possible and typically cheap as possible to keep weight and prices down.
Once I came to terms with that I seemed to not worry as much.
Although, I still think my last camper was made on a Friday close to quitting time or a Monday morning! lol
2020 East to West Della terra 31k3s
2012 Ford F350 King Ranch FX4
DFW Rusty is offline   Reply With Quote
Old 07-18-2019, 08:56 AM   #8
They are for sure!
But you mentioned about not holding your breath... good idea, you'd pass out.
Old 07-19-2019, 04:20 PM   #9
Sadly it's all about the bottom dollar and quality takes the backseat. It's not just this industry but all. I had a few things that I fixed myself rather than drive 3 hrs one way so the dealer could fix it. These are things that should be noticed during pre-delivery.
1999 Chevy Silverado 1500 5.3L w/190k miles (retired)
2016 Chevy Silverado 2500HD 6.6L Turbodiesel
2018 19FBS w/offroad package and 500 watts of solar
Danieloneil01 is offline   Reply With Quote
Old 07-19-2019, 05:17 PM   #10
Oaklevel's Avatar
Typical of any brand RV.... just remember that components like toilets etc. are not made by FR and are used in any make RV.
Top of the line and heavier components would make your RV cost well over 100K and take a tractor trailer to pull.
The parts are cheap and light so we can tow the trailer and afford them.
Bouncing a trailer down the road takes a toll as well.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 07-19-2019, 05:22 PM   #11
BandJCarm's Avatar
^^^^^This should be a sticky.
I've had 10,000 problems. But I'm glad I have what I have, and can't wait to get it back on the road.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 07-21-2019, 07:05 AM   #12
+1
I live in Québec and given the state of our roads, it's a wonder that anything stays in place at the end of any trip. We were lucky and the only trouble we've had with out new TT was a drawer that needed be fixed.
As an HR professional, I also suspect the high seasonality of the industry is part of the overall QC issue. It must be virtually impossibile to run the shops without a small army of temporary, untrained workers in the Spring. I'd be curious to know what percentage of their annual volume manufacturers have to produce between April and July
Claude
2020 E-Pro 19QB
2019 Chevy Colorado Z71 w/Heavy Duty trailering package
ClaudeP is offline   Reply With Quote
quality
« Flt | Ladder »
