Old 10-13-2014, 09:36 AM   #1
Re keying locks
Hi,
New member been lurking for a few weeks. Just picked up our new 831BHDS this weekend. One thing that surprised me is the number of different keys. Is it really necessary to have different keys for the front door, back door, slam latches, etc. Is it possible to change these locks to all use the same key?
-Brett
ncbrit is offline   Reply With Quote
Old 10-14-2014, 04:58 AM   #2
Slympicins's Avatar
I has been down that road as well. Over time you get used to having a maintenance man keyring. I generally keep everything but to do key in the TT. Anything to do with the hitch and truck is on a separate keyring in the truck. Or...just get a bigger key ring. You won't be able to match keys with all the different hatches and doors
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 10-14-2014, 05:46 AM   #3
Rvlocksandmore.com
You can get new storage door cams keyed to your door.
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 10-14-2014, 07:09 AM   #4
Originally Posted by Paul GA View Post
Rvlocksandmore.com
Excellent. Thanks.
Old 10-14-2014, 08:31 AM   #5
mark0224's Avatar
I did the same went to rvlocksandmore.com bought all new entrance door locks and compartment locks and had them keyed all alike. The compartment locks you have on all travel trailers are the same so anyone can open them that has an rv, didn't like that idea. Entrance doors, a lot of companies use the same company to purchase them and they only have small amount of key configurations so if someone gets lucky they may have one of your door keys. The keys I got with the new locks are double sided so they are different than most giving a piece of mind. I think it cost me about $70 to do my doors and compartments.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 10-14-2014, 08:48 AM   #6
HONDAMAN174's Avatar
X3 on rvlocksandmore. They also fixed my miscalculation of measurement at no charge👍
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
HONDAMAN174 is online now   Reply With Quote
Old 10-14-2014, 09:47 AM   #7
Name:	ImageUploadedByForest River Forums1413298017.888037.jpg
Old 10-14-2014, 10:24 AM   #8
That's nice. Wish I would have seen that before I made the rookie mistake!
Old 10-14-2014, 08:34 PM   #9
Slympicins's Avatar
The ever so sad part of this is that if someone wants in your camper, guess what? They are getting in either through your door or window. The worst case is the pry the hell out of your door leaving your with missing silverware ($10.00) and replacing a new door ($500.00). Locks are meant to keep the honest out only. What's a few extra keys?
Chuck and Joanne
Old 10-15-2014, 07:49 AM   #10
mark0224's Avatar
Although this is true, seeing someone walk up to your door and open with a key, less people will notice and say something. I think when they walk up carrying a crowbar someone is likely to notice and say something and get a description. Insurance is going to cover the door but when the criminal claims you gave him the key the insurance may not, and they will claim you gave it to them.
Otherwise why bother to lock the doors at all.
Old 10-15-2014, 07:06 PM   #11
Slympicins's Avatar
Yes I see your point. Guess I will be looking to make a change.
Chuck and Joanne
Old 10-15-2014, 11:45 PM   #12
mark0224's Avatar
Been working around Criminals for 25 yrs by now I think like they think except that they use their thoughts to cause trouble and I use them to prevent it.
Old 10-18-2014, 10:45 AM   #13
Slympicins's Avatar
I have a little over 28 and working on a second retirement in a few years.
Chuck and Joanne
Old 10-18-2014, 11:20 AM   #14
I got locked out of my camper. Deadbolt Key came out at 9 o'clock and could not get the key to go all the way in the cylinder again.I had a bad key cylinder. Not on the recall list. One that they should recall. Notified Fastec. Had my drill and bits in my compartment and very easily was able to drill cylinder out and use screwdriver to turn deadbolt open.
mb2011 is offline   Reply With Quote
Old 10-18-2014, 12:18 PM   #15
mark0224's Avatar
After seeing the posts about the recalled ones I lost confidence in the replacement for the recalled ones. Went to a different company and paid for a different ones and since I changed them I also changed the ones in the compartments.
Old 10-20-2014, 12:08 PM   #16
End of last season, went to lock the camper up, and the deadbolt cylinder pulled right out with the key. Worked perfect up til.that point. Need to order a new one still...
2008 Forest River Micro-Lite 18FBR
2000 Ford Explorer Sports Trac
WBrian is offline   Reply With Quote
lock
